I have used 10.5 heavily for the last week, including a 5 hour round-trip Turkey Day. Certainly there are several areas for improvement, but it is noticeably better than 10.4. Here what I noticed, good and bad.
Car is much more confident in general, with respect to lane changes and turns, however:
- It does not signal when it should (very consistent). Like, if you need to make a lane change to put you in a turning lane, the car only puts on the indicators when you're in that lane, ready to turn. In Ohio you can be ticketed for failing to indicate before ANY lane change.
- Unprotected left turns work much better for me, but right turns on red are troublesome. The car will creep up like it should, but often stops part way into the turn. About 50% of the time I have to nudge it with the accelerator. Right turns on green are very good.
Navigation based issues:
- The car insists on lane changes that are not needed too often. Many surface road trips on a 4/5 lane road with a right turn in the destination, the car will leave the right lane, only to indicate on the screen "an upcoming lane change" to return to the lane it just surrendered. Similarly, even though the car is in the correct lane to make a left turn in a few miles, it will move itself to the right lane, only to need to move back the left lane to eventually turn. In both cases I'm talking about a driving on roads with only the destination turn, otherwise a straight road.
- During my road trip while highway driving, several times the car refused to stay in the right lane. It literally made lane changes into the passing lane. If I used the turn signal to depart the passing lane, it would move itself back after a quarter mile. Had to disable Autopilot for it to stop doing that.
- Frustratingly (but consistent with NoA), while driving in the left lane with a car merging onto the highway from the right, the car wants to merge right and basically block the other car.
Poor weather limited Autopilot:
- In heavy rain the car indicated that "FSD was disabled," or "Limited Autopilot." This is somewhat understandable, but the Auto-wipers didn't think much of the rain, as they were moving like they were set on "intermittent."
- In steady but not heavy rain, while highway driving, the car indicated "Limited Autopilot left front camera XXXX" and told me to take over. Again the auto-wipers weren't moving too hard. Driving a few miles longer the rain let up, and I was able to use FSD again without issue.
I'm confident that there will be improvements,, so I'm not upset about any of the above. However, the whole "not signaling before changing lanes" is something I'm really surprised about in version 10 point anything.
