doctoxics
523
991
Davis, CA
Yes, I think at least some of them are left over from when they actually started to put up some column supports, which they then took down for some reason. Never quite understood that one.
About the time they took down the steel on some of these foundations, Tesla and Panasonic decided not to build Gigafactroy1 all at once, but to build in sections and phase in the manufacturing incrementally.
techmaven
3,617
9,711
They added a floor, so they didn't need to start on the next phase yet.
rsquared99
238
44
Surprise AZ
When I first read the report of them taking down the extension metal works, I assumed it was to use the material in the second floor addition. My thought was that they used that material because the actual material for the second floor wasn't scheduled in for some time. Of course, it was entirely a conversation in my own head, so that could have been totally off base.
Reactions: Krugerrand
JRP3
Hyperactive Member
Aug 20, 2007
19,432
42,585
Central New York
I'm guessing that the first floor pieces are designed specifically for that location in size and load carrying. Wouldn't make sense to use something designed for twice the load on the second level.
techmaven
3,617
9,711
It might also be that the design has changed, so it doesn't make sense to build something that might not be the right thing in the end.
tander
1,508
1,499
Does anybody know if they are still planning on doing an unveiling sort of thing this summer? I had originally heard it was supposed to be last month but it has gotten pushed back for some reason.
SW2Fiddler
We Are Cognitive Dissidents
Mar 19, 2014
2,362
3,246
Houston TX
Originally it was to be in April.
No date given yet (someone from Ohio or Virginia will surely post to tell us:)).
austinEV
3,231
7,352
Austin
That is reasonable. An even simpler theory is that the steel isn't rated to be weatherproof for a long time?
JRP3
Hyperactive Member
Aug 20, 2007
19,432
42,585
Central New York
Possibly, but I'm not sure what would happen to it in the desert, and I doubt it's unpainted or not coated with something. Large construction projects can remain open for a long time.
pmadflyer
355
44
Shawnee, KS
I think I looked at a simplified GF column and concluded that adding a mezzanine floor actually decreases required column size. The unbraced length is decreased enough to offset even a very heavy floor. The shorter length means it's less prone to buckling for a given loading scenario. I might take another look.
TesAus
870
121
Sydney, Australia
Three cheers for Leonard Euler!
Out4aDuck
110
71
Green Bay
When you buy structural steel these days, each piece comes from the supplier cut and drilled precisely to the customer's requirement. It would be very unusual to take it down and re-purpose it. I would guess that the plans for the section under construction must have changed completely.
ecarfan
19,186
13,841
San Mateo, CA
Tesla sets July 29 date for Gigafactory Grand Opening event
Quote: "Tesla has marked July 29 as the date for its upcoming Gigafactory grand opening event to take place at the factory just outside of Reno, Nevada. The announcement was made via email to Tesla owners who participated in the company’s Referral Program and won by referring five or more Model S sales between November 1st to December 31st of last year."
SMBowen
Model S ____
Feb 25, 2016
11
4
Alexandria, VA
I'll put it here, but might post it as it's own thread. I will actually be traveling out to NV that week, if someone can't make the opening event that received an invite, I will gladly go in your place. :)
Reactions: SCW-Greg
Matt Stanley
28
19
Greenwich, CT
The grand opening is set for July 29th. If you were invited you would have been send the following email from Tesla
Congratulations on winning tickets to the upcoming Gigafactory Grand Opening! We appreciate your support and participation in the Referral Program.
We are excited to announce that the Gigafactory Grand Opening event will take place on the evening of Friday, July 29th at our facility outside Reno, Nevada. For your travel coordination, the closest airport to the event is Reno-Tahoe International Airport (RNO) and we have included a list of nearby hotels below. As a reminder, you are permitted to bring one guest to the Grand Opening.
An official invitation will be emailed to you in a few weeks. In the interim, please direct all questions to [email protected]. We look forward to seeing you there!
With warm regards,
The Tesla Team
Reactions: tander
bonnie
I play a nice person on twitter.
Feb 6, 2011
16,427
9,739
Columbia River Gorge
With warm regards,
The Tesla Team
To be clear, that email was sent to people that qualified for the invite through the referral program. A 'Save the Date' only, to allow the winners to make travel plans in advance.
It's very likely that others will be invited, but I don't have a clue as to the criteria that will be used. Hope to see many of you there!
