FM Radio DIYer's might want to look at this. If you are wondering what the connection to the back of the MCU2 digital port (J27) looks like, here's a pictures. It did not exists on MCU1. I had to disassemble my dash both sides, remove my MCU2 so I could get to the back of the MCU so that I could simply plug that white cable into that black J27 port. Its the connection between the MCU and the Model 3 Tuner2 that I am using.
Its the new port to the left of the green Fakra connector. One empty, one plugged in with the Teslatap custom cable.
DIYer's if you intend to add the FM Tuner2 to your car, you might want to get the Tuner2-MCU2 Ethernet twister-pair cable and get it routed to the bottom of your MCU1,behind the cubby before you take your car to the SC for MCU2 installation. Otherwise, you will need to do what I did - remove MCU2 just to plug the cable in to J27
If you look at this next picture, you will understand the tight-quarters we are working in. Use these pictures to get a reference point by noticing the RED and GREEN Fakra connectors plugged in. Notice next to the GREEN Fakra the square black hole. That's J27. (You can barely see the GREEN Fakra connector with it's purple spot.) This picture is taken from the far right side of my MCU, after I removed the right side dash trim and stood on my head to take the picture. I tried taping the new cable to a wooden 12" ruler, a long reach tool pickup, and long needle nose pliers trying to experiment with pushing the cable in without removing the MCU. Nothing came close.
I encourage you to get a cable, or make one thread the path from about where the OBD II port is, to the underside of the MCU/cubby area, so its there and ready. Once you take your car in, make a special effort to get the tech to simply plug your new cable into the back of the MCU before they button up the dash. Maybe they will as its only a 15 second effort if the cable is loose at the bottom of the MCU. Otherwise, you are doing it yourself later. Even if you have not procured your Tuner2, its a good idea to have this done, while its easy. Else you are in for an 1-2 hour effort later.
