Tesla lugnuts
Discussion in 'Model S: Driving Dynamics' started by capt601, Dec 6, 2014.
  1. capt601
    capt601 Vin02324
    Mission Viejo, California, United States
    For the second time I have had the tesla lugnuts lose there shape and cannot get a socket to fit on them or the socket just spins around the lugnut
    The first time last year tesla was rotating our tires and had to replace every single lugnut. Yesterday I had 2 tires replaced from the usual inside wear, and today went to check them and cannot get the socket on half of them to check the torque. Went to the tire shop and they agreed. They said for me to get some from tesla and they will reimburse me, but also mentioned the tesla lugnuts ahve a soft sleeve over them that is easily damaged and warped from applying the 129 ftlbs of torque.
    Has anyone had this same thing happen? Have you found any that work and match the wheels ( silver turbine)? Or is the tire shop maybe using more than 129 ftlbs of torque? I have used them many times and didn't have this problem before.
  2. captain_zap
    captain_zap Electron tamer
    Redmond, WA
    Are you using a 19 mm socket? I think they are metric. I haven't had any issues.
  3. capt601
    capt601 Vin02324
    The only one that fit was a 22mm socket. And those we're the lugnuts tesla installed last year.
  4. gaswalla
    gaswalla P4201/85/airsusp/pano/19i
    San Diego
    This happened to me at discount tires in San Diego.. Service center advised only to hand torque the lugs... Service center gave new set of lug nuts .
  5. siai47
    siai47 Member
    Deland, Fl.
    At least on my car with 19's, it takes a 21 mm socket. A six point impact socket fits fine in the recess in the wheel. Make sure you use a six point and not a 12 point socket. It's not English as a 13/16" socket is the closest fit but is too tight to get all the way on the nut.
  6. omarsultan
    omarsultan Active Member
    Northern California
    Look for a thread by artsci on replacement lug nuts....
  7. scaesare
    scaesare Well-Known Member
    NoVA
    Yes on deforming the lug nuts.
    Yes on the 19" wheels needing a 21mm socket.
    Yes on the recommendation of a 6-pt socket rather than a 12-pt.
    Replacements from the Service Center are $3.50 ea. :)
  8. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Do NOT let anyone use an impact wrench on the Tesla lug nuts. It will distort the nuts and ruin them.
    I recently helped a friend swap his winters on, and the idiot at (insert well-known tire chain here) who put his summers on had hammered them on so hard with an impact wrench that they had distorted. I had to use a 22 mm socket to get them off because the 21 mm would no longer fit. Judging by the force required to break them loose I'm pretty sure they were at 200 ft-lbs. The nuts are destroyed and he's going to have to get them replaced.
    Here's the recommended procedure: break the nuts lose with a breaker bar. Then you can use an impact gun to spin them off. Once the wheels are swapped you can use the impact gun to spin the nuts on again, but do not let the gun hammer them on. Use a proper torque wrench set to 129 ft-lbs to finish the job, and be sure to use a "star pattern" to tighten them.
  9. linkster
    linkster Active Member
    USAX2
    +1
    E X A C T L Y, and *ONLY* use a 21mm 6-pt
  10. jerry33
    Texas
    No kidding. Mine are all screwed now too after the last tire change.
  11. artsci
    artsci Sponsor
    Timonium, Maryland
    I would recommend replacing the stock Tesla lug nuts. Frankly, they're junk. See this thread.
  12. Cottonwood
    Colorado
    #13 Cottonwood, Dec 7, 2014
    To be extra careful (probably more care than needed), I torque the lug nuts to 100 ft-lb all around, then to a final tightening to 129 ft-lb in the classic star sequence.
    And of course, I only use a 6-point, 21mm socket with hand breaker bar and torque wrench.
  13. kevincwelch
    kevincwelch Active Member
    Chicagoland
    I had one deformed by an impact wrench. I had to remove it manually with a 22 mm socket. My fault. To loosen, I do it now with a 4-way wrench and then use the impact wrench for rapid removal. Hand tighten with the 4-way then finally with the torque wrench.
    Little scuffs don't bother me since I use the OEM caps to match the darker color of my wheels.
    21 mm OEM.
    19 mm Rial Lugano nuts.
  14. capt601
    capt601 Vin02324
    Thanks Artsci. Did you end up getting the gorilla lugnuts others mentioned in the thread or another brand?
  15. artsci
    artsci Sponsor
    Timonium, Maryland
    I got the Gorillas. They've been on and off at least 3 times with no problems. They're very high quality.
  16. capt601
    capt601 Vin02324
    Perfect. Thanks Artsci!
  17. omarsultan
    Northern California
    +1 on the Gorillas - a definite improvement over the stock lug nuts
  18. HankLloydRight
    HankLloydRight No Roads
    Connecticut
    Do the plastic lug nut caps fit well on the Gorilla nuts?
  19. MajesticSound
    MajesticSound Up is LOUDER
    Ft Lauderdale, FL
