Tesla Manual Gear Shifting - For Geeks Only
Discussion in 'Model S: Driving Dynamics' started by gavine, Apr 16, 2015.
  1. gavine
    gavine Petrol Head turned EV Enthusiast
    Philadelphia, PA
    I have been driving for 30 years and my first 20 years was with manual transmissions. The past ten years have been automatics and I hated them.
    This is very geeky, but the other day I "made pretend" I was driving a manual in my Model S. The car has so much pick-up that I found I was "shifting" every second. The key was to not let off the accelerator all the way when "shifting" because I wanted to get close to neutral without regen. Anyway, it was pretty cool and I got to thinking.....If Tesla made a virtual manual shift kit for the Model S, I would be first in line to buy one. They could have a dummy clutch and shifter and set a program that makes engine sounds over the speakers. When the "clutch" is depressed, you can rev the "engine" compete with a tach on the display. It shouldn't be all that difficult to do. They can synchronize the clutch and accelerator to move the car accordingly and have the shifter change the rev sounds to match the "gear' that you're in.
    I know this is nuts but it would be so cool.
  2. Thud
    Thud Member
    Atlanta
    While we're at it, let's put a metal crank on the front of the car that you have to turn vigorously a few times before it will start.
  3. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
    If you drive mountain roads, or roads with lots of bends, then you already get the feel of a manual transmission with the single pedal driving of the model S.
  4. caps04
    caps04 Member
    NJ USA
    I like this idea. If they can do creep mode and low regen mode to ease in drivers of automatic, why not create a virtual manual gear shift effect and a at least a virtual gear stick on the tPad!
  5. thecloud
    thecloud As rhythm raced inside, the ship came alive
    Sunnyvale, CA
    I've also been driving a long time, and the first half of that long time was spent shifting gears in cars with manual transmissions. Yes, they were fun to drive back in the day. They could also be hell in stop-and-go rush-hour traffic.
    But I have a hard time understanding why anyone would want to pretend that a Tesla has a manual transmission, or an internal combustion engine that makes revving noises. Why would you not embrace the fact that it has an insanely powerful, silent electric motor with no need for gears? It was one thing to be 8 years old and scotch-tape a playing card to the spokes of my bicycle, pretending it had a "motor". It's quite another thing to have reached a point where the vehicle I'm driving is so advanced that it has no need to pretend to be a bicycle, or anything else from the past.
    However, you're clearly still having fun behind the wheel in your Tesla, so more power to you (pun intended). :smile:
  6. gavine
    Philadelphia, PA
    #6 gavine, Apr 17, 2015
    There's actually a market for this kind of stuff -->
  7. ThosEM
    ThosEM Space Weatherman
    Annapolis, MD
  8. Max*
    Max* Charging
    NoVa
    I can understand this. I was looking for an AWD+Manual car in the US, and there's only a limited selection of them nowadays. When I test drove the Model S, I would occasionally reach with my right arm looking for the gear shifter.
    I could've sworn there was another company that does manual electric cars. More like a roadster, than a Model S...
  9. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    This app does some similar things. Run the app through the stereo and it will use the accelerometer and mimic acceleration, shifting (if you back off the accelerator to mimic shifting), cornering and braking.
    XLR8 on the App Store on iTunes
  10. gavine
    Philadelphia, PA
    I just downloaded it. My wife is out in the car so I can't try it yet, but just tilting the phone makes it respond. It's pretty cool. I can't wait to try it.
