  • TMC Podcast #11 will stream live Saturday at 1PM PDT. We will be joined by special guest JT Stukes, a former engineer at Tesla. You can watch it live and participate in the chat on YouTube. We will addressing viewer comments and questions. For more information, follow the TMC Podcast #11 thread.
Tesla Model 3 and Zappi charger
Hi guys, I'm encountering problems with the Zappi charger, installed few days ago.
In FAST mode everything works correctly. In ECO the charge self stopping randomly and seems to start again alone after I open Tesla app or Zappi app.
Someone with same problem? It's annoying because I would charge with solar when it's producing and continue to charge with grid when sun goes down.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
Hello
I have a Model 3 and Zappi 2. I find (although I haven’t tried it for a while) that Eco+ doesn’t work when the output from the solar panel falls below 1.4kW (Zappi requires a minimum output of 1.4kW) repeatedly. The Zappi is fine but the Tesla doesn’t like the continual on/off and stops the charging, I had to physically unplug the cable and plug it in again to get the charging to restart. Now, I have the Zappi on Eco (with maximum solar input), which means it will use the grid to keep the current at 1.4kW, and all is well. I have set the Tesla to start charging at 09:00 and the “Stats” App to stop the charging at 16:00 to maximise the chance of solar being used.
Not perfect but it works.
Reactions: jjrandorin
Hello
I'm in ECO mode, don't use ECO+ because I know is bit annoying.
It's ok ECO for me, but I don't know why the charge self stops. :(
Any suggestions?
Thanks!
You are probably better off checking with MyEnergi or associated forums directly. However, I have seen similar problems that have been fixed with firmware updates from MyEnergi.
Reactions: Rocky_H
