Tesla Model 3 Down: Won't Power Up, and is Inaccessible
Discussion in 'Model 3' started by MarkS22, Feb 10, 2018.
  1. mongo
    mongo Well-Known Member
    Michigan
    I'm starting to think they may have connected the frunk access circuit to the wrong terminal on a relay (NO instead of NC)...
  2. luckyruby
    luckyruby Member
    United States
    I pick up the car tomorrow but here's what the service center said about the issue:
    • Informative x 10
  3. stopcrazypp
    stopcrazypp Well-Known Member
    So your issue was actually the drive unit, not the inverter or DC-DC.
  4. mongo
    Michigan
    Looks like an drive unit overcurrent fault caused the pyro fuse to activate thereby cutting all HV power.
  5. Smelias
    Smelias Member
    Boca Raton
    Hi all!
    I want to let everyone know that I finally received my Model 3 back from Tesla and I couldn't be happier. They replaced the computer module and updated the firmware to the latest version. Two days in and all is great. I am soooo happy to get her back.
    • Like x 6
    • Love x 4
  6. DrLegoHair
    DrLegoHair Member
    Orlando, FL
    Interesting. This is exactly what happened to my car the first time it was in the shop. I hadn’t seen many people post about bad drive units. Hopefully it doesn’t turn out to be more common.
  7. atokosch
    atokosch Member
    Maryland
    What software did they update you to? I have a Model 3 that is literally 6 days old. This happened to me today.... (I picked up on Saturday 3/17) Tesla had to tow my car from work to the service center and I was given a loaner Model S in the mean time. I am currently on 4.9 and I am eagerly awaiting 10.1, were you given 10.1 to fix the issue? If so, then I am just hoping that my 12V battery was just not being charged due to the bug. I am just trying to figure out, what it could be, I really just want my Model 3 back...
    Thanks for any help in advance!
    • Informative x 2
  8. MarkS22
    MarkS22 Member
    Morris County, NJ
    I was upgraded to 18.4.8 on February 19th. It should’ve been fixed. If you’d like to have your SC contact my SC to compare notes, feel free to PM me.
    • Informative x 2
  9. MarkS22
    MarkS22 Member
    Morris County, NJ
    Has anyone been able to duplicate this?
  10. mongo
    Michigan
    Only cases I've read are your that eould open when 12V was present and the other which wouldn't when the 12V was dead.
    @outdoors fancy testing out your tow hook cover?
  11. MikeBur
    MikeBur ManualPilot
    Seattle, WA
    #591 MikeBur, Mar 23, 2018
    Apologies. Why do we think this is incorrect behavior? Similar to the X, the frunk is able to be accessed at all times, ie HV disconnect is via the frunk and if emergency services cannot get in vehicle then this option is always available. Same as the X it’s not a place for valuables.
    I know then manual says if car is not powered up then you can use this to enter the frunk, though it doesn’t say this works only if the 12V power is off ;)
    Edit: the above is incorrect. Note as @mongo says, the manual does actually say this is NOT meant to happen if 12V power is present. Leaving as is to ensure @MP3Mike disagree remains valid :)
    • Disagree x 1
  12. mongo
    Michigan
    Yes, it does. Page 17 of January 3, 2018 Model 3 owner's manual:
  13. MarkS22
    MarkS22 Member
    Morris County, NJ
    Heh. I mean, only Tesla knows the preferred behavior. They’ve know about my results since February, so it’s really on them to do what they want. The general belief was that it’s only supposed to function if 12v is dead as additional security feature over the manual/mechanical releases on the X/S. First responders have plenty of tools (like a Halligan) that can easily open a hood in an emergency. In an accident, who’s to say the mechanical release wouldn’t get mangled?
  14. MarkS22
    MarkS22 Member
    Morris County, NJ
    You’re not pleased with that sample size? That’s like 5% of all Model 3s delivered. ;)
  15. mongo
    Michigan
    Oy! I'm not the one asking about other instances/use of the scientific method. ;)
    (5% in Michigan maybe :))l
  16. MikeBur
    MikeBur ManualPilot
    Seattle, WA
    I stand corrected, I just went and reread the note. Thanks for taking the time to respond, rather than just hit “disagree”... lol, I’m looking at you @MP3Mike ;)
  17. MikeBur
    MikeBur ManualPilot
    Seattle, WA
    True true, and the manual does actually state that this is NOT meant to work... so, it’s a bug with the wiring, or bug with the manual...
  18. RDaneel
    RDaneel Member
    New Jersey
    Mark, is your 3 working well? I know Greg wants to get his hands on it for the paint protection, and I want him to have tons of experience before he does mine! ;-)
  19. DrLegoHair
    DrLegoHair Member
    Orlando, FL
    Well, as I said in a previous post I could not open my frunk with jumper cables or a 9V when my 12V system was apparently dead..
    After I got my car back and it was working fine, I was easily able to pop the frunk with the 9V method.
    Still doesn’t explain why my SC said they were able to access the frunk with a jump pack?? o_O
  20. DrLegoHair
    DrLegoHair Member
    Orlando, FL
    Please keep us updated. I’ve had 12V issues similar to you but the underlying cause was said to be missing CAN messages which caused the DC converter to disconnect and kill the 12V. I asked if it could be software related and they seemed to think no.
