Tesla Model 3 Drive System Validated after 1 Million Miles of Testing
Discussion in 'Model 3' started by Kermee, Oct 15, 2018.
  1. Kermee
    Kermee It's Not Easy Being Green
    WA, BC & HKG
    It's purdy.
    Tweet: The Model 3 drive system is designed and validated for over 1 million miles – this is what the gears look like after testing...
    • Like x 4
    • Informative x 3
  2. Nocturnal
    Nocturnal Supporting Member
    Kansas City
    Pics broken.
    Edit, that's crazy. They look brand new.
  3. voip-ninja
    voip-ninja Give me some sugar baby
    Colorado
    The motors also made it 1M miles? Amazing if so.
  4. Kermee
    WA, BC & HKG
    Yeah. Pretty amazing if so. My assumption would be yes, since AFAIK, the motors are sealed and enclosed inside the same drive system. I know Tesla is aiming for 1 million miles for their Tesla Semi which apparently currently uses four of the Model 3 drive systems according to Electrek.co. So the 1 million miles drive system testing and validation on the Model 3 makes sense.
  5. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    Wonder what is causing the few infant mortality drive units we have seen on the 3? My neighbor had his fail on day 2 of ownership and I have seen a few reports here of others failing early as well.
  6. ℬête Noire
    ℬête Noire Active Member
    TX
    #6 ℬête Noire, Oct 15, 2018
    Wait a second.
    (1,000,000 mi / 60mph) = 16,667 hr
    16,667hr / 24hr/day = 694.4 days
    That would take nearly two years running constant to hit that mark. Even it you bumped it to 100 mph it's over a year. It also means it would (EDT: not) factor in the extra wear of stop/starts. Hmmm.
  7. JeffK
    JeffK Well-Known Member
    Indianapolis
    Model 3 has been in development since 2014-ish.
  8. Nocturnal
    Kansas City
    Elon probably borrowed the time machine prototype from the DeLorean division.
    • Funny x 6
  9. Eth3r
    Eth3r Member
    More road trips here I come!
  10. Electroman
    Electroman Well-Known Member
    TX
    Good question.
    Somehow these kind of simulated lab-miles really mean very little when it comes to actual road miles in dirt and grime and other conditions.
  11. voip-ninja
    Colorado
    Not necessarily true. The drive units are sealed so the only "real world" things that they might not be reproducing in the lab would be road vibration & shocks as well as temperature variations.
    Tesla could also go with the argument that 1M miles in lab conditions works out to say 750K miles in "real world" conditions. In any event they are demonstrating that these units are wayyyyyyy more reliable than internal combustion engines. Modern ICE are extremely reliable and require minimal maintenance, but they will still require regular servicing and major servicing on most around the 100K mile mark and most would need some kind of rebuild or refurbishment (new rings, rods, re-bore, gaskets, etc.) around 200K-300K miles.
    • Like x 7
  12. Nocturnal
    Kansas City
    Yeah, I think it's a whole different system than what we normally think of it terms of an ICE engine. Contaminants from combustion/moisture etc.
  13. Kermee
    WA, BC & HKG
    I see what you did there... ;)
  14. North75
    North75 Member
    MA
    I hope they did a lot of aggressive starts and stops.
    Running steady speed for 1,000,000 miles wouldn't be that bad if the lubricant holds up.
  15. woodisgood
    woodisgood It's walnut, beech
    San Francisco
    Really will be interesting to see how these cars age. 200K miles is the gold standard for ICE cars, and even to get there you limp through many brake jobs, a timing belt or two, and probably countless other repairs. Imagine if these cars can get to 500K with little/no maintenance. Paradigm shift in more ways than one!
    • Disagree x 1
  16. outdoors
    outdoors Always roaming
    off grid till Xmas
    Know a few labs here locally. Both OEM and outside testers. These places run 24/7 and it is under some crazy conditions they subject everything from motors to interior light switches. So in summary they don't just turn it on and let it run. They do the things these evil minded engineers must sleep at night dreaming of torture, and apply to what they work on.
    I could only get about 250k out trucks that I had to haul stuff with. Spent the money. Did the repairs/maintenance. Eventually the question became. Do I want to be in the middle of X when it dies? So at 250k they were deemed no longer reliable. Motors/tranny. Rings and drilling stuff is not worth it unless you are in diesel world. Move on unless its a farm truck.
    Would love to see a Model 3 with an original motor at a million miles. Hope even more it will be mine.
    • Informative x 2
  17. Az_Rael
    Palmdale, CA
    Eh, its all the rest of the stuff that breaks on Teslas that will keep them from being a paradigm shift for a while yet. Once they catch up with making reliable "normal" car parts, then things will change.
    I have owned 3 Teslas. They have all required more trips to the service center than any prior car I have ever owned. I tell people they are the least reliable cars that I love anyways.
    • Like x 5
    • Disagree x 1
  18. ℬête Noire
    TX
    "Sugar happens."
    As per my post, though, there's timing issues for being able to include typical start/stop duty cycles rather than just running constant (even if under load, assuming they had a test harness that could simulate load and still be durable enough for near 24/7 uptime).
  19. Daniel in SD
    Daniel in SD Well-Known Member
    San Diego
    How long did the original Model S drive units last in this test? I kid because I love :D
    I wouldn't be surprised if gasoline engines can go 1 million miles in a lab. I think it's a little soon to start bragging about Tesla's reliability.
    • Like x 4
  20. SD_Engnr
    SD_Engnr Active Member
    San Diego
    My front drive unit didn't make it to 1k miles o_O. I'm hoping the replacement unit is of the same revision as the ones that made it to 1M miles.
