Tony_YYZ
Tezler Guru
YuppersIs it required by law to have front license plate in Ontario?
Finally, found the time to take some photo after installation.Awesome, thanks. Post some pics when you receive it.
The other brackets such as the Law and the Bandit are way too overpriced for what they are. This one looks like it functions closer to the Law at around half the price. Still a lot for a bracket but less in the grander scheme of things.
View attachment 312126 View attachment 312127 View attachment 312131 View attachment 312130
It happened to me too. Tesla won't delivery the car without the front license plate on regardless any requests.Nice! Looks great! I bought the same mount (Bozzmount) and had it delivered before picking up my Model 3, but Tesla had already put on the mount that comes with the car. I'm getting Tesla to remove it, just so I don't ruin the paint (plus I asked on multiple occasions for them to leave it off) before I put my mount on.
Notice any differences with it on vs without?
I can’t say that the bozzmount is the best option as it’s the only one I’ve used but it’s a really nice look at an excellent price.Those who got Bozzmount is it the best option as Bandit seems to drag a bit from i1Tesla review.
Had good success with this, inexpensive as well.
No-Hole Tesla Model 3 Front License Plate Installation kit | eBay
or
I can't see this causing cooling issues, the part of the vents that are blocked will just get bypassed...ie, the airflow volume wont be affected, so the cooling capacity wont be altered I think.Does it use just one anchor? I only see one in the picture. I wonder if it gets in the way of the cooling vents for the battery - have you noticed any cooling issues?
Why not just stop by Home Depot and buy them separately, can't see them costing more than $5.....
Also, it looks like it will basically 'squeeze' the plate holder against the front lip of the car. Not sure what that would do to the paint over time. I guess you could add a cushion behind it, but this solution isn't for me after looking closer at its design.
These are made out of stainless steel. You wont be able to find them in local hardware store. You need stainless stell otherwise it will rust especially in northern climates.I can't see this causing cooling issues, the part of the vents that are blocked will just get bypassed...ie, the airflow volume wont be affected, so the cooling capacity wont be altered I think.
On another note, it is cheap, but the auction says you have to use the Tesla supplied front license holder, so effectively you are paying $13 USD + $11 shipping, so ~ $31 CAD for basically two lag bolts plus anchor clips? Why not just stop by Home Depot and buy them separately, can't see them costing more than $5.....
I didn't notice any cooling issue, the vents are still exposed.Does it use just one anchor? I only see one in the picture. I wonder if it gets in the way of the cooling vents for the battery - have you noticed any cooling issues?
Paint would only protect so much, stainless steel is the way to go IMO, Paint is a surface treatment but stainless steel is steel with chromium added at the time of material manufacture so it is more durable against road salt and other abrasive chemicals present in the road.I went the budget route, think it cost me $2.50 CAD at Home Depot. My car is wrapped and I put a little weather stripping foam on the back of the plate holder so its nicely cushioned. I didn't consider rust but I'll give them a shot of spray paint and that will sort that out. They is very minimal blockage of the air flow. It's not that hot where I live so I don't see any issue.
For this reason, tail pipe ends in ICE cars are not made out of steel anymore, they use stainless steel.
Ummmm, those bolts in the pic on the auction definitely aren't stainless steel....unless its a lighting trick those are already rusted. I agree that the clips are not rusted. I'm sure you can find some coated ones on McMaster Carr if need be, but then you'll get a pack of 10 or more....maybe people should do a group buy and split themThese are made out of stainless steel. You wont be able to find them in local hardware store. You need stainless stell otherwise it will rust especially in northern climates.
What size toggle bolts did you use?
For anyone that has done front/full PPF, did you put a front license plate holder on with adhesive tape?
Would that pose problems with sticking on the film (i.e. won’t stick on film as well as it would on he bumper)? Or would sticking the holder on the film perhaps put pressure on the film and lift it away from the bumper surface?
