Red Sage
The Cybernetic Samurai
I typically use bold on formal names of people, companies, organizations, and things.
And I really like overkill.
Range comes from higher capacity batteries.
The EPA changed their testing method to a 5-cycle instead of a 2-cycle process, just in time to test the Tesla Model S variants -- which had been engineered to the old 2-cycle process. As a result of that change, all of them were rated at about 90% of the range that Tesla Motors had expected.
I believe that Tesla Motors will be able to create a 60 kWh battery pack for the Tesla Model ☰ that uses only 60% of the battery cells that were in the original Tesla Model S 60. That gets you well beyond the 20% reduction in weight. With the Gigafactory supplying batteries, the price per cell goes down by 30-33% each. So you effectively will have 60 kWh of storage for only 40% of their cost in 2012. You get to use all the storage in a smaller space, at a lower cost, without having to resort to having a wimpy car.
As I said above, range comes from kWh capacity. The more you have, the further you can go. I expect that to work out like this as EPA ratings:250 ⇒ Model ☰ 60
318 ⇒ Model ☰ 85
505 ⇒ Model ☰ 135
Target | Range EPA(5) | kWh battery | Probability* |
Minimum | 200 | 45->50 | 100% |
Medium | 300 | 80->85 | 80% |
Maximum | 500 | 130->135 | 3% |
I'm going to throw my guess out there for 50kWh for the base Model ☰. 45kWh is likely too small to achieve 200 miles EPA range.
Just to compare, the currently most efficient EV is the i3 with 81 miles of EPA range using 18.8kWh (22kWh pack). That translates to 46.4kWh for 200 miles even assuming no buffer (using the 18.8kWh number).
It is just not space to put in anymore, if it should have space for 5 passengers and luggage.
The roadster is a sport car with two seats and original batteries is from 2008. (6years) the development is going in the right direction but it takes time.
A100kW park or higher will be on the X and S long time before the Model 3.
Personaly I prefere long life expectance, on the pack before 400miles range.
sigurdi
While we can safely assume that the Model 3 will be a much better vehicle than the i3, I don't think it's safe to assume it will be more "efficient," just longer range. The Model S is actually not all that efficient a vehicle, they just placed aesthetics and function above efficiency (and rightly so) The i3 is quite likely to be a lighter weight vehicle than the Model 3, and that alone leads to large efficiency gains. (The carbon fibre plastic panels instead of aluminum, and the smaller battery both pretty much guarantee that)You might be right here, I have not made a precise calculation here, just giving some numbers that is in the right ballpark. But in 2017 I think i3 is not longer the most efficient EV on the marked
34,990 ⇒ Model ☰ 60.
42,990 ⇒ Model ☰ 85
47,990 ⇒ Model ☰ P85+ AWD
54,990 ⇒ Model ☰ P135+ AWD
If the P135+ AWD Model 3 is $55,000 that will destroy Model S resale value. You are also saying Tesla (bolded) will only charge $7,000 for an additional 50kWh capacity when they charge $10,000 for 25kWh additional capacity now?
If close to that, Model3 will be truly a "3-series killer".
Well, one of my suggestions is that even the 60 kWh version of the Tesla Model ☰ should actually have an 85 kWh battery pack that is software limited. People could pay the difference in price after purchase to get the extra range. It would simplify inventory so that you wouldn't have to keep track of which packs were installed off the line, except for what I presume would be a 135 kWh battery pack in the top-of-the-line version of the cars.I just do not [see] batteries [above] 85kWh for the S or Model 3.
Here is what I was speaking of before... Let's use round numbers to illustrate what I think about this. Also, this will presume that Tesla uses as few battery cells as possible to achieve the expected capacity in each battery pack:...Tesla do not get [enough] batteries for the demand, this is getting better, but will be a [bottleneck]...
Vehicle | # Battery Cells |
Model S 85 (2012) | ~7000 |
Model S 60 (2012) | ~5000 |
Model ☰ 85 (2016) | ~4200 |
Model ☰ 60 (2016) | ~3000 |
To the other discussion in this thread: Red Sage, I love your enthusiasm (I really do!), but respectfully, you are nuts if you think Tesla is going to ship a 500-mile range M3-besting performance car for $60k.
Look at current Tesla option pricing to guide you; this is how I'm planning for my Model III, anyway:
$35k base price
+$10k bigger battery
+$10k performance package
+$10k options (tech package, pano roof, dual chargers, etc.)
+$5k performance options (spoiler, larger wheels; I expect 17" for base and 19" as the upgrade)
And you're at roughly $70k.
Once again, this is precisely the argument I have made all along. The top-of-the-line versions of Porsche Panamera, BMW 7-Series, and Mercedes-Benz S-Class are all fully 50% more expensive than the Tesla Model S P85. Thus, I expect that a BMW M3 will cost roughly 50% more than a Tesla Model P135+.How that car will compare to a BMW M3 on a track remains to be seen, but Elon has made it very clear about one thing: the MIII will torch the M3 off the line. And if you think that's a bit cheap compared to the Bimmer, remember that the Model S costs a lot less than some of its competition (particularly the Panamera) and outperforms them. It's a big reason why the Model S is eating many of its competitors' lunches right now in its category.
$35k base price
Tesla doesn't seem to lack for buzz and folks writing articles about them.
As a Tesla investor, I want Tesla to live up to their vision statement about EV adoption that Elon laid out many years ago. If a M3++ helps that, so be it. I don't give a crap if the M3++ improves margin by .9%, but I definitely care if working on the M3++ slows down work towards more mass market cars.
I think he's referring more to engineering resources, which Tesla has a limited amount compared to other companies (seems like Tesla can only really work on one or two things at a time).High performance variations in no way slows down moving down market. That is a function mostly of battery chemistry and cost.
To suggest otherwise is ignorance.
10k minus "conservative 30% savings on battery from gigafactory."
I'm a little confused, because though I may indeed be nuts, it seems as if you agree with me...
Range comes from higher capacity batteries. That's why none of the numerous production electric vehicles that top out at 24 kWh have a range that greatly exceeds 60 miles of use in the real world. Trust that if Tesla Motors could give you a 200+ mile range with 24 kWh of energy storage, they would.
Precisely. The problem is that Tesla Motors originally expected the Tesla Model S 60 to be rated at around 230 miles of range by the EPA. The EPA changed their testing method to a 5-cycle instead of a 2-cycle process, just in time to test the Tesla Model S variants -- which had been engineered to the old 2-cycle process. As a result of that change, all of them were rated at about 90% of the range that Tesla Motors had expected.40 kWh ⇒ 160 instead of 180
60 kWh ⇒ 208 instead of 230
85 kWh ⇒ 265 instead of 300
Because of the fiasco that took place the last time, I don't think Tesla Motors can risk trusting the EPA not to screw them again. If Tesla engineers a car that they know will just barely scrape past the 200 mile barrier, say... 220 miles or so... then the EPA only gives them credit for only 90% of what the car can achieve again, that puts them at only 198 miles of range. Your example of shooting for 210 miles might yield only 189 from the EPA. Tesla would be raked over the coals if the car doesn't get a 200+ mile range rating from an independent source, such as the EPA
The range is really just a matter of the projected capacity of the battery pack for the top-of-the-line version. I expect that the majority of people will purchase the Tesla Model ☰ sort of like this, over its lifetime:I guess my point is that I don't think Tesla will be releasing a 505-mile car in the Model III line anytime soon. Period.
Vehicle | % |
☰S - Sedan | 70 |
☰M - Minivan | 20 |
☰X - Crossover | 5 |
☰C - Coupe | 2 |
☰W - Wagon | 2 |
☰R - Roadster | 1 |
Trim | % |
60 | 10 |
85 | 60 |
P85+ | 20 |
P135+ | 10 |
I have actually written precisely that elsewhere, on the Tesla Motors Forums. I didn't mention it in this thread, because it was about comparisons of the BMW M3 and Tesla Model ☰. I think far too many people are way too pessimistic about Tesla's future. So yes, I believe a 135 kWh version of Tesla Model S and Model X will appear for sale by 2016. I expect that the option for that battery pack size will definitely be available in time for an AWD Model S. Unlike some, I believe that the first owners will receive their Model ☰ before the end of 2016.If (or rather, when) they get there, it's going to be on the Model S first.
We'll see. Though, honestly...? The phrase, "Yes, WAY!", comes to mind... BTW, I believe the 'Drive It Like You Stole It' range will probably be ~350 miles. On the BMW? Well... Uhm... Not so much. :-DAnd there's no way an AWD performance car with 500-mile range is going to be $70k.
Well, I do try to point out that what I write on the subject is a [WHISKEY ALPHA GOLF] as often as possible. I just try to support that notion with the limited information I have available to me. Then I try to back that up with Third Grade mathematics for the sake of minimal argument. Since this is about projections for the future, I choose to focus on what I believe the minimum goals for an awesome future should be...That's just wildly optimistic. (Though again, I love your optimism! :smile: )
I hope that a coupe is among the launch vehicles for the Tesla Model ☰. But I'm not holding my breath for it. Coupes sell in very, very, very small numbers compared to sedans, minivans, crossovers, SUVs, pickup trucks... But again, this thread is a comparison of the Tesla Model ☰, versus the BMW M3, and that car is to my knowledge usually offered as a coupe, or 'two-door sedan', even if a four-door is on offer.And I'm not sure if you meant to suggest that a MIII AWD Coupe will be available at launch (i.e. 2017), but I don't think there's much chance of that.
I believe that Tesla Motors will show at least three vehicle configurations at the introduction of Tesla Model ☰, hopefully at the North American International Auto Show in Detroit, January 2015. I do not expect a coupe to be shown among them, but I desperately pray for it. I expect that a five-door liftback sedan, minivan, and crossover (or wagon) will be shown. There is an outside chance that a compact three-door liftback will be shown. There is a strong hope by many I'm sure that a hardtop convertible 2+2 will be shown. I don't want any of those.Those features will come online later after the initial launch of the sedan.
I accept they may not have done it 'on purpose'. The result is the same. It allows Naysayers to claim that Elon Musk lied.Not sure I agree that the EPA screwed them the first.
The car was engineered to meet the 2-cycle protocol. That involved a certain distance traveled at 55 mph on level ground. The Tesla Model S 85, driven on level ground at 55 MPH will go 300 miles. If you use hypermiling techniques (AKA, 'Drive It Like A Hippie Tree-Hugger'), you can get the car to 400 miles.If I'm a buyer which is closer to the actual range owners are getting? Tesla's 300 miles or the EPA's 265?
Typical driving habits of anyone who complains about range are that they 'Drive It Like You Stole It'. So, for them, 'real world range' is something like 70% of the EPA rating, on the low end -- 180-195 miles. Typical driving habits for people who drive 'The Approximate Posted Speed Limit' (wink-wink, nudge-nudge) generally yield ~230 miles 'per tank'. The EPA does neither in their testing. People who are careful about the Wh used per mile typically can travel the full 265 miles and have 'extra miles' left over with relatively conservative driving at around 5 MPH below the posted speed limit.When you factor in the real world, weather and typical driving habits the 265 rated range is certainly more accurate, especially for someone considering purchasing the Model S.
