rogbmw
Fun reading this thread....but everything is pure guesswork at this point. Heck...we have not even seen/driven the Beta X yet!
Because this logo exists, I won't be using MIII or MIII or M/// or even M3. Until such time as a logo is unveiled, I'll be writing Tesla Model ☰. It represents a numeral '3' and I pronounce it as 'three', even as I think of it as 'E'. Whether you see it as 1337-speak or not is up to you. I'm pretty sure that someone doing a search online will be able to find Tesla Motors Club and the various posts on Bluestar, Generation III, or Model ☰ without issue. Oh, there is also the fact that I am not a BMW fan.
Read my post #28 again:That car starts at $62,400. I decided to use the configurator to 'build my own' version of the BMW M4 Coupe. For some reason, it is unfortunately not available in RED. That's a real shame, but I chose the Sakhir Orange Metallic, which is close enough. I piled on the interior packages for Driver Assistance Plus, Executive, and Lighting. I added every Performance, Convenience, and Entertainment option. Well, all except the $350 'power rear sunshade', anyway. That brought the total to a whopping huge $88,875. Close, but not quite $100,000.
My vote on this is to call it the "Model 3" or abbreviate "TM3" to differentiate from BMW. You'd think Tesla would have thought about this since they claim the BMW 3-series is the target of the TM3. -<whee>-Yes that is the BMW logo and it already exists. Thing is Tesla hasn't released the logo or even a rough sketch of the Model 3 yet. Wouldn't it make more sense to write what Tesla says they'll call it instead of making up a logo just for clarity? I know writing three lines sideways looks cool and there are 3 lines and it looks like an E in the old Model E and all. Tesla isn't calling it MIII or MIII or M/// or even M3 rather Model 3 or Model III as some news outlets have written. Tesla so far has simply said Model 3. I put that in bold for emphasis. Anyway, it was just a suggestion but up to you of course.
Yes. Because this is a comparison that JB Straubel himself has made. Specifically, he said that the Tesla Model S 85 achieved a higher capacity using fewer 18650 battery cells as compared to the Tesla Roadster at 53 kWh.When you estimate the battery size on a Model ☰ to 135kWh you use the Roadster 56kW battery compared to the S85.
The 56kWh Roadster weights 990 pounds ...
It seems here you are comparing the form factor of the battery packs, not the number of battery cells encased within them. The Model S battery pack is a completely different form factor, designed to at once be a stressed member of the frame once installed, as well as to be readily removable for the sake of battery swaps. Neither of those functions was required or engineered for the Tesla Roadster. The battery pack for the Tesla Model S is purposely overbuilt and armored to minimize intrusion and thermal runaway to be as safe as possible in the event of an accident. It is necessarily heavier because of these engineering concerns, not because of the weight of the battery cells themselves.http://www.teslamotors.com/roadster/technology/battery and the S85 clocks in at 1323 pounds.
The battery cells remain the same size and form factor. They are 18650 cells. I'm pretty sure I've said that I expect the capacity to increase, not the size of the cells to decrease. I'm pretty sure I've said, though perhaps not in this particular conversation, that fewer 18650 cells, with higher capacity, could together in an array, store a higher amount of energy....when the battery chemistry gets better you can get smaller and lighter batteries with same capacity or the same size with higher capacity.
I don't know if Straubel ever said something like that, but if Straubel said something to that effect, he may have been talking about the Model S 60kWh. That one has 14 instead of the 16 modules in the 85kWh, which means 6216 cells in the 60kWh pack. So it has more capacity than the Roadster with fewer cells.You know this for a fact? The Roadster has 6,831 cells if I remember correctly. The Model S 85 kWh pack has 7,104 cells.
And with new factory build from scratches, who says they have to stick to 18650 form factor?
I would be careful about using only the 60kWh for comparison as it appears to use less energy dense cells. The 85kWh has 7104 cells, which means a 46% improvement (using 56kWh for Roadster).53kWh with 6831 cells vs 60kWh 6216 cells is a increase of 24.4% (from 2008-2012)
The same progress from 2012 to 2016 (as mentioned before) will give a model S or X a 106kWh battery pack with same size as the 85kWh today.
Not a 135kWh pack that need to be 20% smaler in size.
Hope for a 100kWh pack option in the model X.
sigurdi
Right now, yes. Tomorrow, maybe not. The 18650 battery cell is a known quantity, studied in depth by JB Straubel for well over a decade. The amount of energy stored, its rate of discharge, its lifespan, its resistance to the elements, its chemistry, volume, weight, and capacity and any variables among them are all fully understood. So the software balancing, electronic control systems, and temperature protections that are designed to work with them are optimized specifically for the variables of the 18650 form factor. All those things would have to be designed again from scratch to work with a different cell size or configuration.Smal cells is better, but do they ned to be as big as 18650?
Well, they told us yesterday on the conference call that they will not stick to 18650 form factor. The new cells will be about 10% wider and 10% higher(?). Something like 20710 maybe?
I did expected a wider cell, but not taller. Rather I guessed on a shorter cell to make the "surfboard" thinner and give more legroom in the car.
I was pretty surprised to learn they intend to make any physical changes to the battery cells themselves. I had been under the impression that JB Straubel had vetoed that necessity. He did specifically say they would stay with cylindrical battery cells. I have thought all along that an 85 kWh battery pack would be possible, and that the minimum that would be offered is 60 kWh, for the Tesla Model ☰.
They have said the optimal size is about twice the size of the current cell. I expect wider but not lower. Lower would make the surface area to volume ratio even worse on the sides (in practical terms only the sides of the cell can be used for heat exchange). The existing 26650 format would match this criteria perfectly.Yes, they have told us that they think the cylindrical form is best for temperature control. But is also been said that they may alter the size a bit. On that ground I expected it to be wider and lower.
