Good test, thanks for doing it.
Just pointing out that aerodynamic drag is going to increase dramatically with speed, and your tests were done at a relatively sedate 100 kph (62 mph). Faster speeds will make tremendous difference. On the other hand, the colder air is more dense, so greater drag. Also the assumption that other factors affecting your range (temperature, rolling resistance increase from road conditions, etc.) will result in linear effects you have due to the added pod and rack is not necessarily valid. Note that any added headwind is roughly equivalent to adding that wind speed to your driving speed, and aerodynamic drag is proportional to the square of the vehicle speed.
I am a little surprised and encouraged by your results, but I would expect as much as twice the range hit at typical US highway speeds.
