Tesla Model 3 SatNav; SWMBO had enough it's navigating to the wrong places
VanillaAir_UK
7,289
4,787
Surrey, UK
If I get the chance, I will try and repeat tonight.
Repeating this, paying a bit more attention to what is going on, Satnav it may only be using the initial part of postcode as hinted by the destination showed. So quite a wide area. That would explain a lot.
Google Maps, spot on location (to the building) from calendar event
Tesla Sat Nav, navigation location loaded automatically from the calendar event - format house number, town, county, postcode. Wrong side of the A road/dual carriage way. Ironically, the Chipguard (I can recommend them [as Paintguard] for PPF if you are south coast)pin was my location. I should have shown as sat nav, but you get the idea that it simply takes you to the wrong location in some situations.
This is also the case when manually entered, ie my RG40 1SS instance further up the thread. I bet if I checked, RG40 would cover both locations and it just chose London Road, RWG40.
Yep, this is RG40 which straddles the A329 and M4 at one point road.
So I recon that Tesla sat nav just picks a road of same name somewhere in that major post code area and sets navigation to there. Even if you supply a more precise postcode.
Reactions: jimbo_hippo
jimbo_hippo
279
285
Manchester UK
What 3 words support would be great.
https://what3words.com
What 3 Words is a brilliant idea that only people who need a very specific location seem to get.
When it first came around, I shared it and people just kind of stared at it. Only those that were involved in mountain rescue or delivering stuff ever got it. Shame. It’s a great solution to an awful lot of real problems.
Adopado
3,341
2,513
Scotland
Depends where you live. My postcode covers an entire village of around 50 residences spread over a square mile or so. This includes houses up dirt tracks and various drives and only 2 named streets!
Same here ... same postcode houses can be a mile away up a different road and then along a track off that road. Delivery drivers frequently need to be directed despite their satnavs.
VanillaAir_UK
7,289
4,787
Surrey, UK
After a quick check of deleting stale navigation history in 2020.48.10, I'm hoping that this issue is now resolved. I haven't tested this feature for a while so likely to have been resolved earlier.
It certainly gets the correct location for navigating to Chipguard, both with the navigation in the history and with a fresh location with Apple maps and sending the location to the car.
I didn't get the opportunity to check the RG40 example.
For those new to this, previously the navigation only appeared to use the first part of the postcode, so if you had multiple roads of the same name road in the main postcode district, or a long road that spanned multiple postcodes, navigation would typically get the navigation destination wrong, even if sent as a dropped pin.
Previously, this would have taken us the wrong side of the dual carriageway, red arrow. If using dropped pin, it actually drops it in the correct place.
New upload_2020-12-12_16-48-9.png vs previous View attachment 502872
snowywhite
43
16
London
Slightly related - I’ve recently got issues with the voice guidance - specifically at roundabouts - the map shows second exit correctly - but voice says take first exit - sometimes third
has someone else faced this issue
andyaight
38
42
Tutbury
Mine will not store my home address, it always wants to navigate 200ft further down the street i live on. This happens even when I add a manual location on the map. I live at number 1, Tesla thinks this is number 9 ?
AndrewGR
363
166
Oxfordshire, UK
An inability to consistently correctly count roundabout exits has been reported for a long time. Sometimes I wonder if it thinks you are going to go round the roundabout the wrong way! I’ve taken the wrong exit a few times as a result. I don’t like having to check on the screen whilst negotiating an unfamiliar roundabout.
Yachtsman
225
75
Staffordshire
Mines has not taken me to the wrong location (as yet) however is does seem to have a strange routeing effect algorithm.
I can't make my mind up whether it uses the shortest route or just avoids major roads but I'm often routed through housing estates with speed bumps.
Oh, and it can't count exits on roundabouts!
Maybe thats it, it thinks i drive too fast & just wants to slow me down.
Roll on some routeing options.
interbear
697
592
Monmouthshire, UK
For anyone going to the Bristol SC, then ignore the sat nav when it tells you to turn into the Fed Ex site, go straight on to the end of that road and turn left, then carry on to the end of that road and the Tesla SC is hidden on the left.
The chap in the Model S that beeped at me when I was obviously lost, had also found the place hard to find. The chap in the SC just said that most people had a problem finding them, and they really need to update the position pin on the map...
If you do drive into the Fed Ex place, and carry on far enough into their rear car park, you can just see the rear of the Tesla SC, behind a steel fence, not that it helps you find it.
I did this too. Fedex workers out for a cigarette break pointed me in the right direction, I’m sure this is a regular occurrence for them :)
