I did a Porsche Taycan Turbo run recently and made a kind of extended video comparing charging speed, efficiency, range and the charging infrastructure.
In my oppinion, the Taycan can barely hold up to a Model 3 in terms of range (at higher capacity) and efficiency and once the Roadster comes out at the same price point as the Taycan it will be pretty much game over for Porsche. So unless you care for the brand or just wanna show off based on the brand, there will really be no reason to purchase a Porsche at this price point.
I also show the consumption of Model 3 at 100mph avg.
My take from my test:
- The Taycan does indeed have an O.K consumption at higher speeds, but most people will never drive at 200km/h so they will never see that. It is on par with Model 3.
- At lower highway speeds of around 80mph the Taycan is around 50-80% less efficiant than a Model 3 LR AWD/P
Mostly due to its weight and worse drive unit efficiency
- You can expect around 210-240 miles of range, but only because Porsche released more capacity at 88-89kWh, instead the claimed 83.7 on their website. The EPA did their calcuation with 83.7. If you take the EPA and use 89kWh you actually come to about 235 miles.
Porsche Taycan reportedly getting enhanced battery pack to improve range
- At 100mph avg you can expect around 130miles and at 115mph avg you can expect 115miles
- The infrastructure is lacking and you don't have so many chargers each 150-190miles runs which is bad for the Taycan.
