Tesla Model S Parts for sale
jake20Y
17
Wiliamsburg, MI
Front Seats, gray color, great condition $500 (from 2013 Model S)
Next Gen Rear Heated Seats, full set, gray color, great condition $1000 (from 2016 Model S)
Rear 2nd Row seat frame $200 (from 2016 Model S)
1032224-00-A SRS Safety Restraint Airbag Control Module $200 (No Crash Data)
1005273-00-F SRS Safety Restraint Airbag Control Module $200 (No Crash Data)
Brand New Carbon Fiber Dash and Console Trim set, 4 pcs, $1000 (fits Model S and X)
1010906-00-C Body Control Module with key fob $350
1010906-00-D Body Control Module with key fob $350
BJ32-3200-HB 2012-2015 Power Steering Rack & Pinion Assembly $350
6009278--00-F 10kW On Board charger module Gen 1 $350
6006351-00-C Front Left or Right Air Spring Shock Strut $250
6006352-00-C Rear Left Driver Side Air Sprint Shock Strut $250
1097814-00-A 2017-2018 HomeLink Control Unit Garage Opener $250
6006403-00-A Air Suspension Compressor Assembly $250
1012209-00-B High Voltage HV Main Battery BMS Board $250 (from 2012 Model S)
1004422-00-E Front Instrument Panel Dash Wiring Harness $250 (from 2012 Model S)
1004423-00-E Front Body Wiring Harness with Fuse Boxes $250
1005312-00-E Front Right Body Wiring Harness $200
1004417-00-E Front Right Body Wiring Harness $200
1004416-00-E Front Left Body Wiring Harness $200
Signature Edition Left and Right Side Markers Turn Signals $200
1057356-00-A Column Cover, Switches, Heated Steering wheel option $200
6008047-00-E Battery Coolant System Pump $200 (from 2016 Model S)
6006359-00-A ABS Brake Vacuum Pump with bracket $200
1004556-00-D Top Roof Headliner Light Wiring Harness $150
6007092-00-A Rear Sway Stabilizer Anti Roll Bar $150
6007084-00-D Front Sway Stabilizer Anti Roll Bar $120
1043961-00-B Rear Sway Stabilizer Anti Roll Bar $150
6008118-00-A RWD Brake Power Master Cylinder with Booster $150
Front Right Passenger Side Door Window Glass $150
Self Leveling Air Suspension Compressor Pump Valve $150
6007373-00-E Battery Coolant System Pump $125
Panoramic Roof Upper Trim Bow Cover Panel Zuma Alcantara $100
6007572-00-C Front Secondary Lock Latch Assembly $100
1027643-00-A Rear Left Driver Side Brake Caliper with hose $100
1013272-00-E 12V Battery Fuse Box $75
1004293-00-D 6008481-00-A AC Line with TXV valve $100
Chrome Rear Trunk Latch Trim Cover Panel $100
1030182-10-E Junction Box to Charger Port Rear High Voltage Cable $100
1004557-00-E Front End Module Wiring Harness $100
1007512--00-B Sunroof Control Unit Module $100
6005946-00-B Front Windshield Wiper Motor Regulator $100
Right Passenger Side Sun Visor Zuma Alcantara $100
6010351-00-D HV Battery Coolant Tube Break Assembly $100
Dual Motor AWD 12V Battery Tray Holder Support Bracket $100
1033010-00-A Hood Frunk Lock Latch Actuator with Secondary Cable $100
1004425-00-P Rear Left Side Door Wiring Harness $90
1004425-00-E Rear Left Side Door Wiring Harness $90
1004426-00-E Rear Right Side Door Wiring Harness $90
1004424-00-P Front Right Passenger Side Door Wiring Harness $90
6006413-00-B Air Suspension Control Module $90
1013535-00-B AC HVAC Filter Housing Boot $80
Liftgate Trunk Left and Right sensors
1007511-00-A Power Liftgate Control Module $50
1007512-00-A Sunroof Control Module $50
1014388 NEW Parking Assist Sensor with rubber cover $30 each
Ride Height Level Sensors
All Four door actuator mechanism, driver, passenger, rear left and right
All Four door handles, front driver, front passenger, rear left, rear right (from 2012 Model S)
jake20Y
17
Wiliamsburg, MI
What is your price on the door actuator mechanisms?
SnakeDoctorTD
93
90
Houston
Hey, I'm looking for the air suspension sensor links. The plastic part that is typically replaced with "lowering links." Do you still have those, and how much would it be to ship to 77584. Thanks in advance.
cookie99
911
456
related to the person above, i need the plastic piece that connects to the sensor links, 1027941-00-A
