Tesla Model S Side Marker Bulb Replacement
Discussion in 'Video' started by B.TSLA, Mar 26, 2014.
Tags:
  1. B.TSLA
    B.TSLA Member
    B.DOT
    #1 B.TSLA, Mar 26, 2014
  2. pgiralt
    pgiralt Supporting Member
    Cary, NC
    Thanks to Al and Ed's for the video! I know many have been asking how to change those bulbs.
  3. Grendal
    Grendal SpaceX Moderator
    Santa Fe, New Mexico
    What a simple alteration to make your Model S unique looking. I might want to do it just to switch to an LED instead of a halogen bulb.
  4. Babylonfive
    Babylonfive Power12
    Cedar Park (Austin), Texas
    I've wanted to do this for a while - kill off the last non-LED bulb (that I know of).
    David
  5. RLA12194
    RLA12194 Member
    Houston, Texas
    I love it. Anyone have a link to an LED bulb that will work here?
  6. artsci
    artsci Sponsor
    Timonium, Maryland
    These appear to be T3 wedge bulbs. Lots of choices for LEDs and colors.
  7. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    I believe he said T10 in the video.
  8. araxara
    araxara S-P85#3,218 X-90D#3,299
    Tucson, AZ
  9. Lloyd
    San Luis Obispo, CA
  10. PaulusdB
    PaulusdB Mayor Gnomus Vintage Limb
    Europe
    Are you sure? BLUE led's?
  11. Shumdit
    Shumdit Member
    SC
    Maybe his car is blue
  12. Lloyd
    San Luis Obispo, CA
    Goes with the car..... Hey its hip in So California!!
    :tongue:
  13. PaulusdB
    Europe
    #13 PaulusdB, Mar 28, 2014
    That being the case, I'll have to comply.
    Unluckely it's illegal by Dutch regulations. But hey, so are the blacked out taillights and blinkers on my '86 Benz...
  14. Shumdit
    Shumdit Member
    SC
    Video appreciated. Guy should have taken his ring off though IMO
  15. araxara
    Tucson, AZ
    #15 araxara, Mar 31, 2014
    I got the above LED bulbs and installed them (ordered on a Thursday evening and got them the next Monday). They are the same length as the originals, so they fit corrected. The bulbs produce the same color amber light as the front LED turn signals.
    The passenger side is easier to install, since you can fully remove the wiring harness from the fender. I would suggest doing that side first. Also keep in mind which way the harness unscrewed so you can replace it the same way. Otherwise, you will be spending a long time (like me) trying to figure out how to insert it. You should keep your key handy and lock/unlock the car so you can see the bulb flashing to make sure you have inserted it with the correct polarity. Or you can leave the emergency blinkers going, but you will have to deal with removing a hot incandescent bulb. Here a few installation pictures:
    The bulb packaging:
    The Two Plastic Clips That Need to be Removed (sorry for the blurry pics):
    The Installed LED Bulb:
    Short Movie Clip Showing the Blinking Bulb:
  16. scaesare
    scaesare Well-Known Member
    NoVA
  17. araxara
    Tucson, AZ
    If you are going to go with some product from Amazon, I would look at a high out LED. This one looks good and it's 3W and "360º" of light. It costs more, but it has a higher intensity output which you will need in the daytime: Amazon.com: Amber 3W High Power 360-Degree Shine 158 192 W5WB 921 T10 LED Bulbs For Car License Plate, Parking, Interior and Door Lights: Automotive. Also, notice that it has a metal heat sink and the soldering is not exposed - I've had LEDs fail in cars due to vibrations and had to re-solder the LEDs.
  18. scaesare
    NoVA
    Well, being the cheap...er... "value-minded" guy I am, not to mention my preference for a Prime item... I went ahead and bought the Amico units from Amazon that I linked above.
    They are also 360 degree coverage units, and have reviews saying they worked well and were already brighter than the incandescents they replaced... so for less than $4 each, I'll give em a shot.
    I'll let the folks here know how they work out...
  19. Lloyd
    San Luis Obispo, CA
    Here they are in Blue!
    Car is dirty.... wash tomorrow.:redface:
  20. doug
    doug Administrator / Head Moderator
    Pretty sure that's not road legal in California.
