Won't do you much good without the hardware.
The S already has the hardware.
No, you need much longer range for ACC.
PS: Also note the dead switch there. I'm not sure if that goes with the ACC or something else? Auto-pilot anyone?
That test car had at least 4 additional cameras and a radar unit mounted inside
ACC system requires a radar/lidar.
+2 Those who own a car with adaptive cruise and have any highway commuting will always insist that their next car have ACC.
Those who think they are against ACC are like those who thought they were against stability control and antilock brakes and automatic transmissions and seat belts and third brakes lights. Probably most of those luddites aren't people who are likely to be interested in the Tesla as the Tesla will mostly be attractive to people who can appreciate the benefits of auto tech developments.
+1000 once you have it, you don't want to go back.
Not necessarily. I don't use cruise control because of the negative effect it has on power usage, but I have always liked the other items you mentioned. If they could make cruise control that wasn't a power hog, then I'd be all for it as well.
Interesting, in a normal vehicle cruise control is almost always more efficient than the driver manually trying to maintain a speed. If this is not the case in the Tesla then it appears they royally screwed up. In fact, to add to Raffy's post, the cruise control should easily save more power than it takes to operate the electronics needed to do it.Not necessarily. I don't use cruise control because of the negative effect it has on power usage, but I have always liked the other items you mentioned. If they could make cruise control that wasn't a power hog, then I'd be all for it as well.
