If you buy them at the same time then yes Ebay discount the cost.Do i get the $10 off if i buy one X and one S adapter?
I do believe NZ is in the shipping list, check and let me know if not.I would buy a set if you shipped to new zealand?
The diameter of the jack saddle is too small, the weight is not distributed enough. I designed the jack pads to be used with the larger diameter jack saddles. Also those jacks have too small of a foot print to again distribute the weight on the ground and can tip over too easily.How would I go about using a jack like this? http://a.co/d/3NOFvOF
The ebay ad says I can't do it? Can anyone explain why?
I’m personally looking at getting this one: https://www.amazon.ca/dp/B073WB6K7D/ref=cm_sw_r_cp_tai_U57SBb3F288M5The diameter of the jack saddle is too small, the weight is not distributed enough. I designed the jack pads to be used with the larger diameter jack saddles. Also those jacks have too small of a foot print to again distribute the weight on the ground and can tip over too easily.
It’s like riding a bike on a tire half the width it should. Using a jack like that will break the adapter and put your vehicle at risk. Personally those jacks are dangerous especially with a heavy vehicle like a Tesla.
That’s a nice floor jackI’m personally looking at getting this one: https://www.amazon.ca/dp/B073WB6K7D/ref=cm_sw_r_cp_tai_U57SBb3F288M5
Remember you are only lifting one corner so tonnage isn’t the main factor although important, you want a jack with a wide stance to evenly distribute the weight and a large enough saddle to evenly distribute the weight there as well.Is that a better saddle? This other jack I found is 6,000 lbs
- Saddle diameter: 11.7 cm (4.6 in.)
NoWould this one work?
Powerbuilt 620471 Unijack - 6000 lb. Capacity
https://www.amazon.com/gp/product/B00GJJZ5NI
No
That’s a jack stand/jack and the liftnpoint needs to be round.
My pads weee designed to be used with low profile floor jacks with a wide saddle to distribute the weight.
