I've done some searching and I'm not sure I've found a clear answer for using this in combination with jack stands to have more than one wheel off the ground at the same time... So, just to clarify, I'd like to use the Murphy's Law jack pad adapters with my floor jack - they're built for that, good. However, I only own one floor jack and don't trust it to support the vehicle on its own... So, if I want to take both front *or* rear tires off simultaneously, I'd typically use the floor jack to raise the front/rear quarter of the car then slide a jack stand under the car on that side. Then, I'd move to the other side and raise that side with the floor jack and again slide a jack stand under the car on that side. The end result, both wheels are off the ground resting on jack stands and my floor jack is away elsewhere in the garage. Does the Model X allow this or do I need two floor jacks and two adapter pads in order to rotate the tires, for example?
