I think the CA lemon law is if the same issue has been needed to address more than 3 times, mfg will need to replace the car. However, I would look into the details on what the law says.You would have to check your countries laws on this. I think there is a Californian Lemon Law that you might need to research to see if its applicable in your case.
You'll still have 4 years or 50,000 miles to worry about it. More than 3 attempts, lemon law.the concern I have is the service department may do not have the capability to replace the unit as good as the original factor did. It may result in some other issues after few years like when my original warranty expires.
All Teslas have initial issues. Replacing the drive unit is a simple job. Don’t worry. It’s not an engine. It’s a few bolts and electrical cable. Look it up on YouTube. It’s not a big deal. Sure, it should never have happened but it’s not worth replacing the whole car if everything else is good. If you had numerous issues then it’s different. Keep the faith. It will be behind you and you’ll love it.My brand new Model Y, the front engine is dead after less than 3 weeks, and they have to replace the front drive unit. This is so bad experience. Can I ask Tesla to replace a new car? it is only 700 miles on milage.
This is the new paradigm. Ice engines fail after many miles of use. Electric motors usually only fail in the first few miles if something went wrong in production. Otherwise they last way longer with no maintaining. The front drive unit is all one package. It should be easy to replace. I would not worry. It will be good as new because it is.My brand new Model Y, the front engine is dead after less than 3 weeks, and they have to replace the front drive unit. This is so bad experience. Can I ask Tesla to replace a new car? it is only 700 miles on milage.
Actually the "bell curve" is a name used for the function statisticians refer to as "normal distribution". This is about the variations seen in the results of processes. A classic example would be if you precisely weighed the cannon balls produced by a particular mold designed to make 7 pound cannon balls; the majority will be close to 7 pounds, with some a little more and some a little less. As the sample size grows a graph of the exact weights will form a curve shaped like a bell. As the weight gets farther and farther from 7 pounds there are fewer and fewer occurrences. If you monkey with the process, like rejecting any that weigh more than 7 pounds, then weigh the results, the bell curve will be bell shaped on one side and then drop down like a stair step on the other side. The better the process is, the more tall and skinny the bell curve is, a sloppier process will result in a short fat curve, (but still bell shaped).A new car can have failures just as easily as an old car. The Bell Curve applies here.
No need to worry about a front drive until replacement. I hit road debris shortly after buying my MYP, they replace the front subframe and front drive unit. The vehicles rives just as good as day 1. You could never tell anything happened.My brand new Model Y, the front engine is dead after less than 3 weeks, and they have to replace the front drive unit. This is so bad experience. Can I ask Tesla to replace a new car? it is only 700 miles on milage.
