Tesla Motors electric motor vs. YASA electric motor and what is important for EV
nech12
New Member
Jan 13, 2016
2
0
Hi Guys,
After review of several videos and electronic vehicles, I have some questions and may be you can help me with them.
For a long time I was thinking that Tesla produce the best electric motors for e-vehicles (AC Induction). Recently I found YASA motors (http://www.yasamotors.com/) with incredible axial-flux motors. Below is a table that I created to compare Tesla motor vs. YASA motor:
Company / MotorMotor Weight
(kg)
Peak Power
(kW)
Continuous Power
(kW)
Peak Torque
(Nm)
Continuous Torque
(Nm)
Voltage
(V)
Max. speed
(rpm)
Nominal speed
(rpm)
Efficiency
Peak power density
(kW/kg)
Tesla
2015 Tesla Model SP68 375 n/a600 n/a320 15 300 0-5100
5.5
2015 Tesla Model S8568 285 n/a440 n/a320 14 800 0-5800
4.2
2012 Tesla Model S6050 225 n/a430 n/a320 14 200 0-5000
4.5
2007 Tesla Roadster32 225 n/a370 n/a240 14 000 0-5400
7.0
2007 Tesla Roadster Sport32 223 n/a400 n/a240 14 000 0-5100
7.0
YASA Motors
Custom Motorn/a800 400 4 000 1 000
YASA-75033 100/20090 790 400 350/7003 250 0-2500>95%6.0
YASA-P400 Series24 160 100 390 300 700 7 500 0-480096%7.4
YASA-40024 90/16550/70360 250 350/7007 500 0-4500>95%7.5
These numbers have raised important questions to me:
  1. Is peak power density is the most important factor for EV electric motor?
  2. I think that we should look at Peak Torque and Peak Power combination of factors. I mean the best electric motor is a motor with low Peak Power, which means low energy consumption, and high Peak Torque, which means strong driving characteristics.
  3. As I understand, Voltage is also important because if we apply high voltage we will get higher Peak Power and as a result higher Peak Torque. The main problem is that high voltage controllers/invertors cost much more then low voltage (for example 350 VCD vs. 700 VCD).
So I will be glad if someone can validate my findings and comment factor is the most important to consider on electric motors for EV.
Thank you
HI Nech 12,
I know its a long time since you first posted but here's an answer....
The yasa motors are quite incredible but require high voltage to maintain their power over longer ranges. What a higher voltage means is far less current is needed to get the same power. This means that the batteries can run safer and dont require as much cooling (P=V^2/r rather than (P=I^2*R). The tesla motors can be assumed to need between 900-1200A to generate the quoted peak power. The yasa motors run at around 250A max which in my opinion at least is a bit safer. Our motorbike the ION HORSE is running a yasa p400 with the above specifications. The question of which is more important depends on what you need it to do. A peak torque is great but the motors get very hot very quickly if you don't have sufficient cooling to run them at full power all the time. A continuous power figure is what the motor can supply for a period of time and is produced by what the manufacturer tests the motors to be safe for. If you can increase the cooling ability then in theory you can increase the continuous power figure. The density, i think, is irrelevant if you dont know the size and weight of the controller and batteries. As they will certainly weigh more. Our battery pack is around 85-90KG! and the controller is another 15+ so in total the energy density is far than a racing internal combustion motorbike engine. Although a fair bit more useable and torquey.
I hope this helps.
Reactions: Brando
