The HPWC only requires 3 wires, same as the 6-50. You can set dip switches inside it to limit power to 40 amps, so it'll work fine on the 6-50 wiring. You can either hard wire it, or you could buy/ make a 6-50 pigtail and use it to plug in the HPWC into the 6-50 outlet. You could also use your Wattstation, and just use the Tesla J1772 adapter. The downside of that is that the adapter doesn't have a button to open the charge port. But you could buy one of lolachampcars key fob charge port openers for that issue. And finally, you could make a 6-50 to 14-50 adapter and use the Tesla 14-50 adapter.
Hot dog! Thanks everyone for the information. So the wiring I have would work, and I can even limit the HPWC to work on the existing wiring and breaker (though I would hard wire it and lose having an available 6-50 outlet in the garage). That makes the HPWC more tempting. However, it also sounds like you don't need the UMC when using a J1772 EVSE? I thought the J1772 adapter was like any other adapter and it was used in conjunction with the UMC, but from what you say and taking a closer look at the picture of the J1772 adapter, it looks like it does NOT require the UMC, and plugs directly between the J1772 connector and the car. That's actually pretty awesome, and makes me want to continue using the GE Wattstation when I get a Tesla, even though the HPWC is more tempting to me now. All good news, if I understand everything correctly.
I myself have a NEMA 6-50 in my garage. I also have a GE Wattstation (a J1772 EVSE) plugged into it. I have been debating what to do when I get a Tesla. The HPWC is ideal, but how much will it cost to set up? Does it require 3 or 4 conductor wiring? Can it be limited to something less than 80 amps? The problem isn't just buying the HPWC, it's also that it completely throws away my 6-50 installation. It costs a lot to run wiring for 80 amps of current. With that much draw, it might even require a main circuit upgrade (my house is 200 amp, which is okay for a 6-50, but start pushing 80+ on one circuit and it seems an upgrade might be in order). If you have to upgrade the main, how much extra will that cost? Probably a ton.
If I don't need an 80 amp charge rate, and if it might cost a ton to do all the electrical upgrades and buy a HPWC, isn't it better to try to use what I already have? If they don't come out with a new 6-50 adapter, I could just charge through the GE Wattstation (which I picked in part because it can at least do 32 amps, not just 16 amps like some EVSEs). Would it be better to plug in through the GE Wattstation? Not so much if the main connection problem is between the UMC and the adapter, as either way will be using an adapter (right?).
There is a lot I don't know here. I was hoping by using a higher amp EVSE that plugs in to a NEMA outlet using some beefy 6 gauge wire would protect me from having to redo it all again on my next EV purchase. I have both a reasonable amperage J1772 EVSE plus a standard 240V 50A wall outlet. But maybe not.
Maybe Tesla should sell a 40A HPWC?
Mine's for sale for $1,000. :wink:I received confirmation today that the NEMA 6-50 adapter has been discontinued for the foreseeable future, no demand. I updated the FAQ (see my signature) to reflect this. You will have to manufacture your own cable or purchase it from another source (does TonyWilliams manufacture one?)
JakeP posted this link in another thread:
NEMA 6 50 to 14 50 Adapter Plug for Tesla or Other Charge Connectors | eBay
It looks like a good option to plug a UMC into a 6-50.
GSP
Thanks JakeP for the link to the eBay option. After considering this adapter, I decided against purchasing it, because it is not a sealed unit. Meaning it may not work perfectly in less than ideal (dry) conditons.
I found another supplier, Conntek, who make every possible Tesla adapter, in a pigtail style. Here is the link to the 6-50p to 14-50r adapter that I ordered. About $125 in Vancouver, you may get it for less in the USA.
http://www.conntek.com/products.asp?id=971
