I added the Tesla mudflaps as soon as they were available for purchase. By then I had been driving my Model Y for more than 8 months. I had a good idea of where the water, debris and salt was hitting the Model Y. This was all on the front and rear door panels with almost none behind the rear wheels. The rear end of my Model Y got dirty from air and water flowing over the vehicle not from the rear wheels.
Also, the Tesla mudflaps are super easy to install with only the simplest of tools (a flat head screwdriver or a clip removal tool.) The rear mudflaps can be more difficult to install, usually require at least one screw to be installed. I have been very satisfied with the Tesla mudflaps, don't care that the Tesla mud flaps are not available for the rear wheel wells.
I did add the Tesla paint protection film (PPF) for the rear door panels. I had never installed PPF. Installing the PPF requires more prep. You have to clean the area(s) where the PPF will be installed. You need to prepare a spray bottle of slip solution (baby shampoo and water). You need really good lighting when installing the PPF so you can see any air bubbles trapped under the PPF. The bubbles need to be seen so they to be moved out from under the PPF while the adhesive is still wet. I would estimate the Tesla mud flaps took no more than 20 minutes (this included cleaning the area of the wheel wells where the mud flaps go.) The PPF took about an hour once I had gathered all of the supplies, cleaned the door panels.
