Tesla Offer Model 3/Y Frunk Group Buy
Discussion in 'Model Y' started by CLLACAB, Jan 18, 2021.
  1. Wreckz
    Wreckz Member
    Honolulu, HI
    #341 Wreckz, Feb 5, 2021
    Mine was exactly like yours.
    I just adjusted the locking cable so it had minimal slack. Then locked it down with those screws. Not sure the size of those bolts. Just used my needle nose pliers. Make sure the latch is in the open position.
  2. Srad600Volt
    Srad600Volt Member
    Southern California
    #342 Srad600Volt, Feb 5, 2021
    You are not meant to leave the adjuster that loose. In the EG video, the tech actually says to place the latch and the pull cable in their final places and then take the latch back off and adjust the tension of the lock nuts. In the FTG video, they actually show the final adjust locations of the nuts with the slack taken out, but he does not talk about it.
    *EDIT* Wreckz beat me to it! I believe his photo is the correct adjustment. If i remember correctly, both adjusting screws are 12mm.
  3. Wreckz
    Wreckz Member
    Honolulu, HI
    Good to know. 12mm wrench size wasn't on the tool list and I was to lazy to take the elevator back to my Unit.
  4. ToutSuite
    ToutSuite Member
    Los Angeles
    Mobile tech came out today and replaced both clips (I'd only broken one) with newer versions that don't wiggle as much. He saw the Tesla Offer working and was impressed I'd installed it myself, but warned that if I had any trouble with the frunk lid at all, I should swap it out before bringing it in the SC. I assume any trouble I have will be directly related to the Tesla Offer or my install, so I'm not too worried about that.
  5. mm94027
    mm94027 Member
    SF Bay Area
    I dread the day that I would have to remove this! Both arms and hands have cuts all over. I thought exercising and getting bigger arms was supposed to be a good thing...
  6. mcorf
    mcorf Member
    Campbell,Ohio
    Had both of mine installed today. The MARK 4.0 on the Y took them 1 1/2 hours and the MARK 3.0 on my 2019 Model 3 took them 45 minutes. They said the Model 3 was easier because the struts were so easy to take out as compared to the Y.
  7. CLLACAB
    CLLACAB Member
    Las Vegas, NV
    Installed the 3.0 in my M3P today. The only advice I would give is to make sure you mount the control box on that top bracket as close to the windshield as possible. I had it mounted too far forward and could not install the Frunk liner. Had to redo a bunch of zip ties to move it back. To get the emergency cable through, I used a zip tie and pushed it in from the outside and then taped the cable to it and pulled it back through. Other than that, everything was very easy. Probably took 2 hours. Model Y tomorrow.......
  8. CLLACAB
    CLLACAB Member
    Las Vegas, NV
    Installed it in the Y today. System is working but I am having one small issue. The hood comes down but the latch is not grabbing it and pulling it closed. If I put a little pressure on the hood it will grab it and pull it closed. I’m thinking I might need to raise the latch. Have a question out to tech support. Anyone run into this?
  9. TinkyWinks
    TinkyWinks Member
    Bay Area
    Just finished my self install and everything is working fine for me.
  10. bchan911
    bchan911 Member
    Toronto, Canada
    I feel like you didn't align the latch correctly during the re-install. Try making some minor adjustments to the front center latch mechanism and it should work...
  11. ToutSuite
    ToutSuite Member
    Los Angeles
    Someone else had this issue last week. Sounds like they needed to reset the control module? Look back a page or two.
  12. bchan911
    bchan911 Member
    Toronto, Canada
    Post #337 - By 2101Guy
    go out and click your button on the control unit twice in succession. Short presses for both, not long presses.
    Resets the latch mechanism. Thats what Raymond had me do, and it worked.
  13. CLLACAB
    CLLACAB Member
    Las Vegas, NV
    I adjusted the locking cable and it seems to be working fine. My last thoughts: Getting the strut on the driver’s side was an absolute nightmare. As a final resort, I have a screw driver that is about 2 feet long. I used it to leverage the ball joint against the frame and was able to snap it on. Getting leverage in there is almost impossible.
  14. DaveORD
    DaveORD Member
    Chicagoland
    That was my major issue, not easy to do with my big hands that got torn up a lot. My left hand and forearm was much worse than my right, due to that driver's side install, super tight for me. This morning is the first time they look normal again, only a few remnants of scratches remaining. I should have paid the neighbor's kid to borrow his smaller hands to do that part.
    BTW, any idea how many kits TO finally sold via the discount you facilitated?
  15. MY-Y
    MY-Y Member
    MD
    #355 MY-Y, Feb 8, 2021
    I had no issue popping the new one back on. I'm not sure why yours was so difficult. Maybe a bit of lube would do the trick?
  16. xtnvieira
    xtnvieira Member
    Orange County, CA
    To follow up, I was finally able to work on this a bit this morning but none of the suggestions solved the problem. I eventually contacted TO via WhatsApp and Raymond tried to help me troubleshoot the problem, but nothing was working, even updating the unit’s firmware. He said he’s not run into this problem before so he’s going to talk to his engineer and they may have to send me a new control unit.
  17. MY-Y
    MY-Y Member
    MD
    Did you stoop down and look to see if the loop is hitting the center of the catch? I had to move mine over a bit to solve this issue.
  18. bnaritomi
    bnaritomi Member
    Los Angeles
    You got VERY lucky!! I spent (wasted) about a half hour trying to get the upper driver side strut ball joint popped in. What a chore!!
  19. xtnvieira
    xtnvieira Member
    Orange County, CA
    Yeah it’s centered fine. But the latch motor isn’t even engaging when trying to close.
  20. 2101Guy
    2101Guy Active Member
    #360 2101Guy, Feb 8, 2021
    silly question (only because I was dumb enough to miss this part at one point during many latch adjustment tried on my S) but you do have your plug that plugs into your latch, fully seated, correct? And you also tried pressing the control unit button twice in succession to reset the latch?
