Tesla on autopilot crashed
Discussion in 'Model 3' started by BobAbooey, Feb 11, 2019.
  1. BobAbooey
    BobAbooey Member
    usa
  2. Rockster
    Rockster Active Member
    McKinney, TX
    "The driver said he tried to regain control but the car would not let him..."
    I call BS on that.
    So he's an idiot and a liar.
    • Like x 8
    • Disagree x 1
  3. Shateam
    Shateam Member
    NJ
    Jersey drivers...
  4. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    I can totally believe AP might mistake lanes and drive you into a gore point if you aren’t paying attention.
    Depending on what objects were hit before the driver tried to take control, the suspension or tires may have been damaged causing the driver to not be able to control the vehicle.
    So I am guessing they didn’t catch that AP was going off the rails until the car hit something.
  5. Trips
    Trips "Boring bonehead questions are not cool. Next?"
    Omaha, NE
    "The vehicle could have gone straight or taken the Adams Lane exit, but instead went down the middle" Not the first time this has happened. Does having the navigation on help the car know where it should be going?
  6. Dre78
    Dre78 Member
    Chicago, IL
    I'd assume only when Navigate on Autopilot is engaged. Regardless, I won't experiment how it handles a fork in the road until full self driving and HW3.
  7. chronopc
    chronopc Active Member
    I find this to be unlikely as well. There have been instances where EAP has gotten confused and did some crazy maneuvers, but I have always been able to take over control.
  8. MacGreiner
    MD
    The comments on that article . . . oh . . the comments. Grab your popcorn.
  9. brkaus
    brkaus Active Member
    Austin, TX
    Never had issues taking over control. I actually practice it.
    • Like x 4
  10. Glamisduner
    Glamisduner Active Member
    Escondido, CA
    My car has done this before with NOAP engaged, don't trust autopilot completely! I simply took neck control though...
  11. wcorey
    wcorey Active Member
    Killingly, CT
    We probably ought to be careful about claims the AP went 'off the rails'. It is a fairly widely known and experienced issue where, particularly true for left exits, the lane the driver is in transitions to a Y where the exit is on the left and to remain on existing road is to the right. The car sees that, currently, as the lane widening so it, what would otherwise be rightfully, tries to maintain center lane. Using the left blinker tells the car you are turning left, slowing down helps, one up motion of the right stalk to disengage EAP. "The car made me do it" is nonsensical. The mere fact this is beta software and cars do not have regulatory approval to be autonomous, means the driver seat occupant is ALWAYS "pilot in command".
  12. ModelNforNerd
    ModelNforNerd Active Member
    Ayer, MA
    The Derp Patrol is out in full force on that one.
  13. Chancellor32
    Chancellor32 Member
    Queen Creek, AZ
    Who is this guy?? Shaggy? It wasnt me?
  14. voip-ninja
    voip-ninja Give me some sugar baby
    Colorado
    Strong words from someone who was not there.
    As someone else pointed out, the AP could have struck an initial object which caused problems with steering control through damage to suspension, rims, etc.
    We all know AP is not perfect and it has hit things before (multiple cases of getting confused at gore points and hitting an object which have resulted in at least one fatality), even in some cases where drivers were being attentive.... so I find it's not good to shoot bazookas at people who report they had trouble until all the facts are in.
  15. Az_Rael
    Palmdale, CA
    What I meant by AP going off the rails was that AP can and does mistake lane markings and might drive you into the ditch or wall at an exit if you are not paying attention. So it will leave the "rails" meaning proper lane on the road.
    I haven't seen anything where the driver was arguing the car made him do it, so I am not sure where that comes into play. The driver claimed he couldn't regain control, which is fairly easily explained if he tried to regain control after damage to the suspension or tires had occurred.
  16. TjckTock
    TjckTock Member
    Queen Creek, Arizona
    Pretty much every driver in an accident always blames the other driver. 99% of the time. 90% of the time the driver at fault will flat out lie about what happened. (OK, so I made up those numbers - but from my own personal experience I think this is close to reality). So no surprise that they would blame the car now that they can.
  17. jdcollins5
    jdcollins5 Member
    Wilmington, NC
    There are multiple ways to take over from EAP:
    - Steering wheel movement should disable AutoSteer
    - Lifting right stalk should disable AutoSteer and TACC
    - Hitting the brakes should disable AutoSteer and TACC
    Now if the OP was so slow to recognize his situation that he struck something that would disable something that would prevent him being able to disable EAP, how is that the car’s fault?
  18. Kanting
    Kanting Member
    California, CA
    No wonder the huge China EV market said they don't buy AP for trouble. Now they get it for free!
    Joking aside, what exactly is "autopilot mode with Lane Control?" Is it ALC?
