Are the black tubes under ESS coolant tubes?
Mitigation of propagation of thermal ... - Google PatentsTEG, where did you get that diagram? I want to see more!
Searching patent applications at uspto.gov , I see this interesting one
Liquid cooled rotor assembly
Abstract
A rotor assembly cooling system (100) and method of using same are provided. A portion of the rotor shaft (103) is hollow, the rotor shaft including an open end (107) and a closed end (105). A coolant feed tube (109) is rigidly attached to the rotor shaft (103) using one or more support members (111), thus causing the shaft and the feed tube to rotate at the same rate. Coolant is pumped through the feed tube until it exits the end of the feed tube and flows against the inside surface of the closed end of the rotor shaft causing the coolant to change direction and flow back through the coolant flow region, this region being defined as the space between the outer surface of the feed tube and the inner surface of the hollow rotor shaft.
but maybe it's been mentioned here before?
Note that the primary inventor is Peng Zhou, recently in the news and departed from Tesla.
Specifically, pending US applications are not published until 18 months after they are filed, so even with an exhaustive patent search there is no way to be sure that everything pending at the Patent Office has been discovered.
Freepatentsonline finds 4 pending applications:
- 0021385: Electric Vehicle Communication Interface
- 0272661: Liquid cooled rotor assembly
- 0023053: METHOD OF DEACTIVATING FAULTY BATTERY CELLS
- 0023056: BATTERY PACK THERMAL MANAGEMENT SYSTEM
and two granted patents:- 7404720: Electro mechanical connector for use in electrical applications
- 7433794: Mitigation of propagation of thermal runaway in a multi-cell battery pack
