So is mine. I have wondered (in passing, I dont spend a lot of thought on this, lol) if people who attempt to turn off their AC because "I dont want my AC on all the time" contribute to their own issues with this if it still happens for them.
My car is set at 72 during the summer and 70 in the winter, on auto, and I have not had this problem for at least a year.
Hilariously, it seems everyone here is totally willing to let Tesla suck at something they can design around. They can do everything in the world, but somehow drying coils is beyond them so why bother.
Had this after a year owing 3 in GA climate. Changed to aftermarket HEPA filters and it seemed to fix the problem or maybe it was the update that did it. I am sure they will goodwill you since you own car just for 4 month and already have this problem. Good luck and enjoy Future on the wheels.I have a 21 model Y and I’m having the ac stink issue. I’m aware of this happening in other models as stated above. In fact my Jeep had this problem after a couple of years. However, I’m having this problem after 4 months of ownership. I contacted Tesla who has setup an appointment for $129 to change filters and clean the evaporator. My question:
Obviously I know that is outrageously priced. They said they might warranty it if the technician finds an issue with the HVAC. Has anyone had Tesla look at theirs and find an issue with the system? I usually turn the HVAC off when I get home. I have with every vehicle I have owned. I also turn off the music as it is habit.
Is there any fix for this problem? I’ve heard my fan running before but I have had to get back into the car right after arriving at home before. From what I read above I guess getting back in overrides the fan running? I was curious if anyone has run a pre filter or running carbon filters if this helps? I’m debating if I want to pay Tesla to look at this or just clean it myself.
mHad this after a year owing 3 in GA climate. Changed to aftermarket HEPA filters and it seemed to fix the problem or maybe it was the update that did it. I am sure they will goodwill you since you own car just for 4 month and already have this problem. Good luck and enjoy Future on the wheels.
I’m curious if the hepa filters stop the issue. I understand the logic behind why it happens but it seems like that should’ve been resolved in engineering. My jeep had the cabin filters behind the glovebox away from the condenser. Wonder if that is why this is happeningI had the smell, cleaned with Kool It cleaner and replaced filters (with OEM), and the smell is back this summer. Usually I can smell it for the first 10 - 15 seconds of running the AC and then it dissipates so not a huge deal but still annoying.
I don't really understand the apologists who alternately say "never happened to me, so this isn't really a problem" or "you're using your AC wrong" which has very strong Apple "you're holding the phone wrong" vibes. Just admit it's a design flaw which I'm guessing has been improved with the software update but not completely eliminated. I'm thinking it will take future physical design updates to reduce incidences.
Here's a question that maybe someone knows the answer to: are an equivalent number of Model Y's affected with this issue? I know there are subtle differences to the Y's HVAC system.
Supposedly the best way is to run the system on fan only (AC off) for a while before the car shuts off (so that evaporator can dry off). I did that in my previous car anyways to reduce AC usage (when I reach local roads near destination, if it's not too hot, I tend to run fan only and with windows down). However, there was an update pushed that was supposed to do that automatically anyways.I’m a Tesla fan boy so it’s not like I’m going to throw a tantrum. I’m just disappointed this is happening. I’m going to let them look at it and next time might try aftermarket filters. I wonder if leaving the climate in auto all the time is the answer. I was just groomed to turn everything off while growing up as it was easier on the 12V battery.
m
People who say it's never happened to them is not necessarily the same people who have had it happen (sometimes to previous cars they have owned) but claim it's not a design flaw. I think it's hard to claim it's a design flaw if this happens regularly with other cars also (someone pointed to BMW forums). The fact of the matter is the smell is from mold/mildew from the moisture on the evaporator. Depending on the climate you live in, pretty much any AC system may be susceptible to this.I had the smell, cleaned with Kool It cleaner and replaced filters (with OEM), and the smell is back this summer. Usually I can smell it for the first 10 - 15 seconds of running the AC and then it dissipates so not a huge deal but still annoying.
I wasn't aware of that. If that's the root cause, wouldn't it be pretty easy to solve in the aftermarket just with a replacement filter that's a bit thinner and with a plastic shield so the filter material is not directly touching?Lots of active threads on this topic, so I have mentioned this before. I don't believe the wet coils are the issue. It's the paper filters that are getting soaking wet because they are touching the wet coils in Telsa's design. The paper will not dry out as easily as the coils, so the software update that runs the fans for a little while isn't going to solve. Wet paper, made from organic materials, is probably the best breeding ground for mold and fungus. We need new filters that are designed to stand off from the coils and with plastic frames so they don't get soaked.
Great alternative which will also provide a bit more filtration rather those plastic pieces. So no issues with airflow or noise/sucking lack therof?Not an expert (actually, a newbie), but I read that the cause of the smell could be wet leaves, etc., sitting on the other side of the cabin air filter. Putting in an air flow filter by the input (back of frunk) will cut down on a lot of debris. Make sure you pick a filter that doesn't reduce air flow.
I used True Blue 24 x 36 x 1 Budget FRP 2 Washable Filter-HD0124361 - The Home Depot which doesn't affect airflow
Worth considering?
Yes, it's an entirely different case if you had the issue already before the update was pushed, given the mold/mildew is already there. You still have to kill the existing mold/mildew first (which may already be in other parts of the system).So many variables involved, there really isn't a one-fix for them all. In my case, I've had the offending moldy smell 4 times. Each time I've had to perform an A/C condenser foam treatment. Each time my filters were completely dry (dry to the touch - there of course could be some moisture on them). Each time my filters were not an obvious source of odor. The filters smelled like nothing, and turning on the A/C without filters installed immediately reproduced the moldy smells. Each time I treated the coil with a whole can of "kool-it" or similar, the smell would go away, or mostly go away, then would return a few days or weeks later.
I think/hope I've finally knocked out the "true" source of my problem by lysoling and then foaming the heck out of the coils, then momentarily reinstalling the filter cover and turning on the fan to blow all that lysol and foam completely thru the evaporator and up into the vents where stuff could be growing from previous exposure.
It's only been a week since I did this, so we'll see how it goes. But so far everything smells fresh, even when you first turn it on, which is when I would get most of my problem.
My car definitely turns on the fan to dry out the evaporator after its been parked for 10 minutes or so. This "Afterblow" feature (GM calls it that - I had an 07 Impala with this activated on it) of course will only help keep a non-infected system from growing mold. If you already have mold or bacteria, you have to get it all out first before the fan running will do anything. And of course nothing will ever 100% keep your evaporator from growing something organic.... maybe if they install UV lamps in the system to sanitize - of course then your plastic evap case will degrade...
