Tesla Rage Calculator: Why would turning on AC affect 85D more than 70D?
Discussion in 'Model S: Battery & Charging' started by steinegr, Jul 15, 2015.
  1. steinegr
    steinegr New Member
    Austria
    According to the official Tesla Range Calculator turning on the AC affects the 85D way more than the 71D.
    At 70 mph, 19" wheels, AC off and an Outside Temperature of 90 degrees 70D's rage is rated at 240 mi, 85D's is 274 mi. 34 mi difference. Turning on the AC brings the difference down to 15 miles (229 to 244).
    Screenshots.
    Any ideas why that would be the case?
  2. travwill
    travwill Active Member
    Chicago, IL
    Interesting. I'd assume it has something to do with the 70D being more efficient overall. The motors use less voltage/watts by them being restricted but the weight is less as well. So maybe over time that weight of the extra battery/cells in 85D adds up or brings down the 'curve' of capacity versus efficiency a little faster with AC on.
  3. RiverBrick
    RiverBrick Active Member
    Mount Washington Valley
    I suspect it's just a bug in the range calculator. If you or an OP can, please change rage to range in the thread title.
  4. WarpedOne
    WarpedOne Supreme Premier
    Slovenia, Europe
    That resolves into 205 minutes of driving, 292 Wh/mile and average power of 20.490 W
    That resolves into 235 minutes of driving, 310 Wh/mile and average power of 21.850 W
    70D: 196 minutes of driving, average power of 21.430 W : + 1 kW for AC
    85D: 209 minutes of driving, average power of 24.401 W : + 3.5 kW for AC
    What it boils down to is unknown exact available capacity. It is not 70 and it is not 85, so all above calculations are moot.
  5. mattmass
    mattmass Member
    Canada
    But that's my favorite part :)
  6. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    OMG my Tesla give me SO much RAGE, but you'd have to change the calculator to accept
    "Stuck in traffic"
    "Stuck behind a Subaru"
    "Stuck behind old lady"
    "raining, and I can't power slide without sliding into a tree"
    "Stuck behind a prius"
    "Stuck behind a pickup with an exhaust pipe the size of my junk"
    Then accept a MPH, and 'time stuck' and 'lanes of road'...
    Then you could calculate the rage I feel...
