Tesla readying for X assembly
This is definitely great news as it means that things are on schedule (at least the factory side of it)
Has it always been the case that the Model S and X will be produced on the 'same line'? Somehow I thought it was going to be two separate lines.
Although, having toured the factory personally, I'd be hard-pressed to tell you what the definition of a 'line' actually is.
I think they are in the process of modernizing by redoing the current S line to a much larger more automated line that will handle both Ss and Xs. Not sure the existing line will still be around. Based on floor plan in a brief at TMC Connect last weekend.
There was a slide of the plan in Diarmuid Oconnell's presentation. So you should see it on the posted video. Basically, the serpentine, mag-stripe following cart things are being changed, at least partially, to a more "assembly line" kind of set up. It looked like 2 loooong parallel tracks in the area north of (?) the existing factory floor where they have made all of your Model Ss, so far. :smile:
They have lots of room.
I've always heard two production lines, handling both Model S and Model X (when it is in production).
I've recently heard that the current line will be used for engineering prototyping and other one-offs. You know, the stuff that messes up production numbers. "Under Engineering Control", the ultimate oxymoron. :)
princess bonnie's been around engineers for too long.
