Tesla releases new tool for people to retrieve ‘blackbox data’ after a crash
wk057
Senior Tinkerer
Feb 23, 2014
5,652
11,383
Hickory, NC, USA
Not according to the Electrek article, which states quite clearly that Tesla provides full EDR data; it is using the airbag interface to access the data, but the data is not restricted to airbag-related information.
Mainly was just pointing out that this is data recorded by the airbag module. It's not Tesla's logs, AP video/images, etc. The airbag module can record a handful of things, but the EDR data from it is generally less than 1KB.
mongo
12,875
37,931
Michigan
Unless you are in a wreck and it is not your fault and your insurance wants you to pay as the police give you the ticket. Geez.
Not sure EDR has the data you need for that, unless the fault is based on speed or swerving.
From NHTSA:
Since the term "EDR" can be used to cover many different types of devices, we believe it is important to define the term for purposes of this research site. When we use the term EDR in this site, we are referring to a device installed in a motor vehicle to record technical vehicle and occupant information for a brief period of time (seconds, not minutes) before, during and after a crash. For instance, EDRs may record (1) pre-crash vehicle dynamics and system status, (2) driver inputs, (3) vehicle crash signature, (4) restraint usage/deployment status, and (5) post-crash data such as the activation of an automatic collision notification (ACN) system. We are not using the term to include any type of device that either makes an audio or video record, or logs data such as hours of service for truck operators. EDRs are devices which record information related to an "event." In the context of this site the event is defined as a highway vehicle crash.
scottf200
3,795
3,364
Chicagoland ModelX S603
It could be valuable to tell that you were rear-ended before running into the car in front of you. Putting the full blame of the accident on the person behind you.
I guess I was thinking of all the items in red. I recently saw a dashcam video on TMC where a Tesla was sitting at a light and another car in front of it decided it was too far into the intersection when it stopped. The person ahead of the Tesla decided to back up but ran into the Tesla. That person then said the Tesla rear-ended them! I'm sure there are many other examples where speed/brake/throttle/etc could lead to conclusions. i.e. I didn't run into my garage ... the Tesla just hit the throttle itself ... no, I didn't panic and miss the brake but hit the throttle. Wait the EDR data just told the insurance company that you lied. Food for thought on other examples.
Do insurance company give better rates to Mfr and models of their cars that have useable/verifiable EDR data? If so then we all benefit if we have that insurance company. i.e. sort of like the tracking OBDII data to see if the driver is safe or made a mistake. Just another thought.
mongo
12,875
37,931
Michigan
It could be valuable to tell that you were rear ended before running in to the car in front of you. Putting the full blame of the accident on the person behind you.
Valid point, though I'd hope they would find it more likely that the last car rear ended the middle car into the front one vs both the middle and rear cars hit the car in front of them.
mspohr
9,029
10,462
Do we know which boxes in the chart Tesla ticks?
apacheguy
S Sig #255
Oct 21, 2012
5,075
1,238
So Cal
In the event of an actual crash, Tesla will still be able to pull the much more detailed gateway log files and they will provide them to the relevant authorities. They have been doing this for years. This new tool has changed nothing.
mongo
12,875
37,931
Michigan
Depends on the state of the car. The complete kit includes cables for connecting directly to the module and powering it.
apacheguy
S Sig #255
Oct 21, 2012
5,075
1,238
So Cal
The gateway log files are stored on an SD card. Unless the SD card was destroyed, they will be retrievable. Although, if the SD card was destroyed, the EDR most certainly suffered damage as well.
mongo
12,875
37,931
Michigan
Gotcha, thought you were talking about Tesla pulling them remotely, not disassembling to get a card out.
MP3Mike
15,046
31,978
Oregon
Really? I thought the only thing stored on the SD card was the maps.
appleguru
952
1,686
US
Just got a PCAN-USB from eBay (who outbid me on the auction the other day?!)... building a cable now. Will see shortly what if any data this module actually provides (presumably not much without having been in a crash?)
appleguru
952
1,686
US
Does anyone know which CAN bus the airbag module is on?
appleguru
952
1,686
US
Nope, Chassis Bus (CAN6).
*very* boring data indeed, especially if you haven't been in a crash. See attached for a sample report (manually redacted VIN/SN info and the raw data, as their "don't include VIN" option is apparently just for the filename and not the actual data/report...)
Hopefully this saves a curious few from shelling out for the cables/gear needed. While I suspect this might have more useful data about crash sensors, seatbelt tensioners and airbags if you're in a crash, without being in one it is pretty useless/has no interesting data at all. And as wk057 said, this is just reading data from one module (the RCM) on the car. No real telemetry, camera footage, or anything else really useful/interesting.
  • TESLA_EDR_5YJSA1E28GF######_2018_03_12_2037.edr.pdf
wk057
Senior Tinkerer
Feb 23, 2014
5,652
11,383
Hickory, NC, USA
Cool to see a list of things it can retrieve. I plan on trying this on a car with deployed airbags this week. Will post if I can get anything from it.
appleguru
952
1,686
US
Also, in case anyone is curious as to the format of the .edr files that Tesla's site uses to generate the reports... they're just json:
Code:
    "filetype": "Tesla EDR data file",
    "hash": "ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff",
    "payload": {
        "F187": "ffffffffffffffffffffffffffffffff",
        "F190": "0000000000000000000000000000000000",
        "FD00": "0000000000000000",
        "FD01": "ffffffffffffffffff",
        "FD02": "00000000",
        "FD03": "ffffffffffffffffffffffffffffffffffffffffff",
        "FD14": "ffffffffffffff",
        "FD52": "ffffffffffffffff",
        "FD53": "00000000000000000000000000000000",
        "FD60": "ffffffffffffffffffffffffffff",
        "FD61": "ffffffffffffffffffffffffffff",
        "FD62": "ffffffffffffffffffffffffffff",
        "FD63": "ffffffffffffffffffffffffffff",
        "FD64": "ffffffffffffffffffffffffffff",
        "FD65": "ffffffffffffffffffffffffffff",
        "FD66": "ffffffffffffffffffffffffffff",
        "FD67": "ffffffffffffffffffffffffffff",
        "FD80": "0000000000000000",
        "created": "1520901458.84"
    "retrieval_comment": "Tesla EDR Retrieval Program v17.32.1",
    "user_comment": "Comment Here"
