I know this is a small nit but I can't help myself... It's the first two sheets, not bricks. Each sheet has 9 bricks. Each brick has 69 cells for a total of 6,831 cells (11 sheets).
There are some 1.5s in Norway. I don't know how they got there. Didn't the 2.0 Roadsters start with model year 2010? I thought there weren't any 2009 model year Roadsters. No? I thought he cars made in that year were either 2008 v1.5 or 2010 v2.0.
I'm confused how two sheets could add up to 12 volts. As I understand it, the 69 cells are in parallel, so 3.7 volts nominal for a brick. A sheet made up of 9 bricks in series adds up to 9 x 3.7 = 33.3 volts. So two sheets would be 66.6 volts, right? I think it adds up because 11 sheets adds up to 366.3 volts nominal (11 x 33.3), which sounds about right.
By the way, sounds like a great idea to get the 12 volts directly from the pack and makes me wonder why Tesla went to a separate 12 volt battery for 2.0 and 2.5 roadsters. Maybe it was somehow less expensive to separate it? My converted porsche 914 has a separate 12 volt battery and so needs a DC to DC converter to charge it from the Lifepo4 pack. I would guess that the 2.0 and 2.5 roadsters would also need a DC to DC converter, right?
