Tesla Roadster charged wirelessly
Discussion in 'Roadster' started by Raffy.Roma, Sep 14, 2013.
Tags:
  1. Raffy.Roma
    Raffy.Roma Active Member
    Rome (Italy)
  2. elecblue
    elecblue Member
    Singapore (for next 2 years) previously Chicago, I
    Nice idea, but 1-1/2 kW kinda sucks.
  3. Raffy.Roma
    Rome (Italy)
    Maybe that charging an EV wirelessly is not a powerful way of charging but I would like to install it anyway in my garage. So I could always charge my EV when it's parked. Then, if I need to charge faster, I could use a cable.
    - - - Updated - - -
    But from Google it does not seem easy to find a dealer selling wireless charging systems. Maybe that some TMC friends in the USA know how to find dealers selling wireless charging systems?
  4. stevezzzz
    stevezzzz R;SigS;P85D;SigX;S90D;XP100D;3LR
    Colorado
    I may be wrong, but isn't the conversion efficiency of wireless/inductive charging much lower than direct charging? When plugging in the S in your garage is already so convenient, I don't see the benefit or appeal of wireless charging at home. Very cool tech, of course, but expensive to install, slow and inefficient.
  5. Raffy.Roma
    Rome (Italy)
    @stevezzzz
    You are right it looks that the conversion efficiency of wireless charging is not so good (1/3 loss), but maybe it could be improved by raising the source of energy and taking it closer to the car?
  6. shrink
    shrink Supporting Member
    Phoenix, AZ
    These guys claim 90% efficiency for wireless charging:
    Efficiency | Plugless Power
    Efficiency
    Efficient power transfer means your EV recharges as quickly as with the cord
    Plugless Power recharges your electric vehicle as quickly as traditional corded methods by utilizing efficient inductive power transfer technology.
    The Plugless Power technology has achieved over 90% efficiency as measured from your home’s 208/240V electrical outlet to your vehicle’s existing on-board battery charger. This loss of efficiency, which is present in similar electrical devices, does not lead to increased charging times for your EV. Your vehicle will continue to recharge in the same amount of time needed by traditional corded methods, which can range from two to eight hours depending on the size of your vehicle’s battery.
  7. Raffy.Roma
    Rome (Italy)
    #7 Raffy.Roma, Sep 15, 2013
    @shrink
    I also just found out Plugless Power. Very interesting.
    - - - Updated - - -
    Then I was thinking that for Tesla cars having adjustable suspensions this system could have even a better efficiency. In fact it would be good to lower the car as much as possible while charging to have a better efficiency (better coupling to the electromagnetic field).
  8. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    I really do not see the point as it takes me less than 10 seconds to charge with a chord. 5 seconds when I get out of the car to plug in and 5 seconds to unplug. For this 10 seconds of work I am "rewarded" with a 10+% efficiency gain and 5X the charging rate. After owning a roadster for 28 months I have found it is quite easy to plug in and not a problem at all.
  9. Raffy.Roma
    Rome (Italy)
    @David
    If you were sharing your garage with other people in a building and you were afraid of being stolen the chord maybe you could prefer to charge your Roadster in a more discrete way by doing it wirelessly.
  10. woof
    woof Fluffy Member
    The main point of wireless charging for me is aesthetics and safety. No cables hanging all over the place, nothing to trip over or block your movement around the cars. As a secondary point would be automatic charging every time, without having to remember to do it. I've forgotten to plug in on occasion (usually because I need to unload the car of stuff, which I cannot do with it plugged in without having to jump over the cable).
    I'd trade some amount of efficiency for those points.
  11. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Ride height is not adjustable. Shocks and sway bars only.
  12. richkae
    richkae VIN587
    Wireless charging might have a place at a taxi stand or street parking where you don't want to be dangling cords, or street parking where the charge port is on the wrong side of the vehicle.
    In my own garage I would rather have a cord.
  13. asgard
    asgard Member
    Here, in the Bay Area I've had people unplug my car when it was not done charging and use the cable for their own. I can see Plugless as a solution to this problem.
  14. Raffy.Roma
    Rome (Italy)
    Agree. Then if you have a solar power system the energy loss would also be negligible.
  15. dhrivnak
    NE Tennessee
    Not sure I understand where you are coming from here. Solar panels are still expensive and adding extra panels to handle the inefficiency to me is a lose lose. Plugging in is quite easy and high powered. But if this is what most want then more power to you.
  16. JohnGarziglia
    Reston, Virginia
    Need to figure out a way that such a system could be embedded in a road or highway, and the car charged while driving over the coils. Would it be expensive to build? Sure. But such a system could be an electric car game changer.
  17. Raffy.Roma
    Rome (Italy)
    #17 Raffy.Roma, Sep 18, 2013
  18. brianman
    brianman Burrito Founder
    Gratz.
