Hi all,
I know some of you are using https://www.tesla-screen.com from the car's browser to get quick access to features that are missing or harder to do with the regular UI.
I moved the site over to AWS this weekend and changed it a bit. Now, you won't have an account for the site. You'll just log-in with your Tesla account credentials which get proxied over to Tesla to get an API key for data access -or- you can simply login by entering an existing API key.
Unfortunately, Tesla's API doesn't support CORS, so the data needs to be proxied through. Nothing is saved.
The UI runs much better if you are on 2019.12 or higher since Chromium is the new browser. For example, setting charge percent now works in the slider instead of having to type a value.
I also added a Sentry mode on/off to the set of cards.
One last thing, the new UI keyboard "SHIFT" key seems to be backwards - or it is unintuitive. When it appears highlighted, you are in lower-case and vice-versa. If you enter a password, you can't see if it is reverse-case, so play with in in another field first to get the hang of it.
Thanks!
Thanks!
