Doggydogworld
Econo-car doesn't need 5000 cycles (except Robotaxis, ha).I can see Tesla using LFP for somethings, in particular a budget priced compact car.
Cost and cycle life are much more important.For the Semi IMO lowest weight possible for the truck is very important,
Chinese LFP bus packs are now 160 Wh/kg. That matches S/X and even exceeds Model 3. Hopes for a huge density jump with Roadrunner are misplaced, IMHO. Most Semis will be 300 milers. 600 kWh @ 160 Wh/kg is only 3750 kg. You save almost that much in engine, transmission and fuel. So there's no payload problem.
The 500 miler might fall a couple tonnes short in payload, but most trucks on the road are less than 75k lbs and fleets will still have plenty of diesel tractors for those. Semi has many other long haul issues, anyway.
I'm pretty sure MIC Model 3 does. I don't see how 622 could almost match range at the same weight.Is Tesla using a 811 NMC?
Not within the cells, where it matters most.The massive paralleling of cells should drop the I^R losses.
