brucet999
This answer made no sense to me, so I looked up Enphase technical data sheet and found this:It depends on if you hook them up on 2 sides of the AC of your house.,,,or on a single side.
In the case of 240V AC....you had better have a phenomenally balanced system if you plan on running a 240Volt appliance off grid with them. Unbalanced 240 volts can kill appliances.
For instance 100 volts AC on one side and 140 volts AC on the other side is indeed 240 Volts AC, however I wouldn't try and run and air conditioner unit on that. If you happen to have a window air conditioner unit.....it will vibrate your whole house.
The Push-Pull of AC in this situation will be like holding a 30 pound weight in one hand and a 5 pound weight in the other and spinning around as fast as you can.
Nominal (L-L) voltage/range2 240 V / 211-264 V 208 V / 183-229 V
Inputs to main panels in the US are never 120V.
All Enphase micro inverters output single phase nominal 240V or 208V.
