ccutrer
My experiences last weekend was in Beaver, UT which has gen 1 superchargers, and has always been a problem child for me. It had also been recently used (monitored usage with 2 to 4 out of 4 slots being used for basically the hour prior to my arrival; 2 out of 4 cables were still VERY hot to the touch when I arrived). I tried 3 out of 4 before giving up and accepting the 60kW rate. On the coldest handle, it went to 108kW for maybe 30 seconds before rapidly dropping down to 60-ish. The other two I tried didn't even get above 70. I DID notice that at least two of the handles had been replaced (newer button for opening them, rather than the old style that has a physical break for the button). I figured it was just Beaver being Beaver. Then I hit Nephi, UT which is a newer supercharger, 8 stalls, no one there. It did the same thing - 100+kW for a minute or two, then down to 70kW. The handle WAS warm. I only needed about 30 miles of range, so I didn't bother switching. In a few weeks I'll be hitting up Tremonton, UT and Twin Falls, ID again, which have always been reliable for me. If they aren't this time, I'd definitely agree that Tesla changed to be more conservative.But from the other thread, the throttling is happening on brand new units with new connectors too, so the wear theory doesn't seem to be the case.
There is new reported behavior where the supercharger would throttle to a very low level immediately after a few minutes. I don't believe this was ever the case previously. I'm pretty sure there is a change in the algorithm.
