Electric Machete
P#3820
This conversation is only about 19" wheels, right? It was my understanding that the tires on the 21" rims cannot be patched. Or am I mistaken?
I believe they cannot be patched as a permanent fix. Best solution is the repair kit (it uses slime and air) to get to a tire shop or home. But I'm thinking rather than the whole compressor, just a can of compressed air/slime would do the same thing (for $12 on Amazon) for the 21". If the can can't fix it, then the compressor probably couldn't either...
Jerry (or anyone) can you confirm that the compressor included in the Griot's kit will run fine off of the Model S? (Won't blow a fuse.)
Which Griots package? They have 3 but I think none will work while the tire is on the car and when one is away from home:
http://www.griotsgarage.com/search.do?query=tire+repair
Is this kit even worth it? I'm on the fence about buying it. Tesla provides roadside assistance. My insurance also has roadside assistance. So I can always have my car towed either to Tesla or to a tire shop. Other than the time I would have to wait for a tow truck to arrive, what's the value add of having the kit?
I bought this slime smart tire repair kit from Walmart for $29.99. Upon opening the package up, it says the motor is 15amps. If the accessory fuse is 15amps, will it be ok? Or should I return it and get one with lower amps? Where is the fuse any way?
Does anyone know how long it takes to go from a complete flat to full tire pressure with either Tesla tire kit or after market 12V compressors?
Depends on the compressor, but I think the typical 12v model could take 15 minutes or more from complete flat.
At the store, I had the single use can in my hand, but put it back and picked up the Slime kit with compressor. It was only $30 or something like that, came in a nice zippered carry pouch and I figured it might be handy to have the compressor for topping off tires if I'm away somewhere.
If you have a nail in the tire, it has to be removed. Your tire will be fine if plugged properly. If you are a real stickler, then take it to a shop and have an internal patch put on. But for 99.9% of the folks, a plug will last as long as the tire.
Sealant wont remove the nail, which is still a trip to a tire store where they will likely put a plug in .....and, in my experience, sealant rarely actually works unless the leak is insanely slow.
If you actually get a puncture ...say running over a board with a nail and there's an actual hole, you may be able to cram the neck of the sealant tube in there to slow the leak, but you aren't going to stop it.
I bought the $50 Tesla Kit. Is there a way to replace the can of SLIME? Is seems like the can is ONE AND DONE so basically you have an air compressor after your first flat.
