That looks like it might have started to overheat and melt.
Your continual ranting about this topic is permitting you to generate suspect credibility.
To whit:
You are viewing a photograph of a plug head, AND respectfully I disagree with your assessment.
No melting is noticed.
Additionally our comment about overheating is frankly inflammatory (pun intended) and beyond the pale.
You do not
know that it is starting to overheat, you are only
ass-u-ming and speculating, and I suggest you stick to known facts.
In my
real world experiences, I have encountered times in RV Parks where the outlet devices overheated and tripped the breaker.
When the same breaker tripped the third time, I told the ground-crew that it was worn out and needed to be replaced (it was).
And then I went to another charging outlet location, the outlet face was ALREADY cracked before I plugged in.
As I plugged into my car, the ring showed
red, not blue or green, indicating a faulty ground.
The car is
that smart that it detected the ground fault.
That outlet needed to be replaced.
At the third outlet, I was finally able to get a charge without any incident.
I charge my Model S every night in my garage at a 14-50, installed by a qualified electrician.
Yes, it does get mildly warm while charging.
But never hot.
Maybe after you have actually owned a Model S and charged it every day, perhaps
then you will be able to generate a comment with genuine merit.
But at the moment, your tendency toward drama is provocative and in my opinion unwarranted.
