Tesla trying to charge me for front suspension repair
Discussion in 'Model S: Driving Dynamics' started by hemants, Feb 15, 2017.
  1. hemants
    hemants Member
    toronto
    Parts list includes
    washer
    nut
    bolt
    fr susp aft link assy
    Should this be covered by a TSB?
  2. rypalmer
    rypalmer Active Member
    Canada
    Are you within warranty?
    What is a TSB and why would it matter?
  3. Max*
    Max* Charging
    NoVa
    Technical Service Bulletin. Car manufacterers create them for things that they know are wrong with their cars to get fixed.
    Typically TSBs only get applied under warranty. If you're under warranty, it should be free, if not, it shouldn't.
    OP, is there a TSB out for your specific problem?
  4. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    For someone to provide a useful answer to your question, you need to provide more information.
    When did you purchase your car? New or CPO? How many miles? What was the nature of the problem that necessitated installing those parts?
    Information, please.
    • Like x 4
  5. demundus
    demundus Active Member
    Oceanside, CA
    Do you happen to drive on dirt roads alot? o_Oo_Oo_Oo_O
  6. hemants
    hemants Member
    toronto
    What tesla is telling me is that control arm bushings are worn
    The tsb pertains to control arm issues
    The parts list recommended have a lot of overlap.
  7. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    TSBs are typically only covered under warranty. So if your car is out of warranty, then you will probably have to pay for the TSB fix.
    Is your car still under warranty?
  8. TexLaw
    TexLaw Member
    Bellaire, TX
    I'm afraid I must echo the others. If it's not a recall or a warranty repair, it's on you.
  9. demundus
    Oceanside, CA
    You haven't told us your mileage, CPO, original owner, private party, etc... those details help us understand your situation better. If you're out of warranty, a TSB doesn't matter. If you're in warranty it's a document that guides a warranty repair
  10. hemants
    hemants Member
    toronto
    Out of warranty. Guess I'm out of luck.
  11. Akikiki
    Akikiki A'-Lo-HA ! y'all
    Kaneohe
    In my experience, I find the folks at the service center to be quick to tell me if they can handle anything under warranty. I don't even need to ask them. I've not had to question if something was, they are first to tell me if they can. I believe if they could have covered your repair under warranty, they would immediately and let you know they could. Its a totally different service experience that the traditional auto dealership mentality.
  12. RichardD
    RichardD Member
    Texas
    Often times if you ask nicely and prepare your case, they will do everything in their power to help you. Hope you can find a way to get it covered.
  13. Tam
    Tam Well-Known Member
    Visalia, CA
    Did you get your car new? Did you ever bring it in for inspection/service... before it ran out of warranty?
  14. hemants
    hemants Member
    toronto
    I bought second hand. Looks like the TSB was performed in January 2014 but the control arms were not replaced.
  15. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    Does the extended warranty offer coverage for TSBs?
  16. Tam
    Visalia, CA
    Extended Warrant should but only if you could only get it if didn't buy CPO from Tesla and when you bought it from third party, that third party must paid up for Extended Warrant in advance so it can be transferred to you at the time of sales.
  17. HankLloydRight
    HankLloydRight No Roads
    Connecticut
    They've changed the rules, and now second owners can buy the ESA after private party purchase.
  18. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    Was it the same issue in 2014? If so, one argument for coverage was that the underlying cause was never fixed, resulting in the current failure. You might be able to push for a goodwill fix based on that.
    But you didn't post many details on what you're experiencing now, nor what happened in 2014, so it's hard to say.
  19. hemants
    hemants Member
    toronto
    Details :
    TSB : Washer and nut replace, knuckles and suspension link assembly if necessary
    Current Problem : Washer, Nut, Bolts, link assembly
  20. TSLA Pilot
    TSLA Pilot Member
    United States
    Have to concur with others: a more informative post would be useful.
    Cost to repair?
    Miles on the car when you purchased it and now?
    Symptoms?
    Thx.
