I just had my two year service done by Tesla in my driveway. He did the brake fluid check, brake cleaning and tire rotation.
In case anyone else is considering this service - you want to replace the brake fluid after 2-3 years in the lines, not "check" it. "Checking" brake fluid is meaningless.
If you ever track your car, you want to replace brake fluid annually or semi-annually. If you race it - before each event.
Lubricating and cleaning brake caliper guide pins (especially on the rear floating calipers) is a good idea.
I wasn't aware a 2 year service was recommended. My Tesla 3 is 2 years old with 19,000 miles. Which is preferable: a 2 year or a 20,000 miles service?
Brake fluid is hydrophobic, it absorbs water out of the air over time. This happens even if you do not drive the car, so the maintenance schedule is purely time based.
Then water pools at the lowest point in the brake lines. That is usually near the brake calipers. When you use brakes in an emergency, the pads heat up the calipers, which in turn heat up the brake fluid. Water in the fluid boils first, turning into steam, and your brake pedal goes to the floor without applying pressure to the pads to slow the car.
What happens next depends on the circumstances on the road, but wet brown spots in the pants are not uncommon, possibly followed by impact braking.
Brake fluid doesn't degrade over time but it can get water in it if seals are bad. I think they can test for water and if it's ok it doesn't need flushing. If you race the car it's a different story. On non salted roads you don't need any regular service except tires. I rotated the tires once at 10k miles on my LRRD and it doesn't need it again. Front wheel steering and rear wheel drive and braking seems to even out.
This is completely untrue.
Water is absorbed into brake fluid through rubber lines themselves, as well as the reservoir cap (which is designed to freely vent access fluid). This happens regardless of the age and conditions of rubber brake lines and seals.
On both RWD and AWD Teslas, rear tires wear faster. They wear out WAY faster on RWD cars.
Rotating tires prolongs their overall lifespan of the set.
He also pulled the logs from the car to check my battery health. The cost was $137.75, that's really cheap for all the work he did. I was extremely happy with how thorough the brake job was
Cheap or not - if you want to maintain your brakes - you must replace the fluid!
Also, rotating the wheels is something that any one of us is perfectly capable of doing in our own driveways.
Swapping between summer and winter wheels on all four corners takes less than 30 minutes (second time around).
Swapping brake pads (when necessary) adds another 15-30 minutes to the job (it takes longer to take the wheel off and put them back on). Both jobs require only a jack, a torque wrench, and few rudimentary tools that most folks already own.
Bleeding the brake fluid requires a pressure bleeder, and only adds another ~5 minutes per corner (once wheels are off).
Buy Motive Products - 0108 Brake System Power Bleeder for Most Late Model GM Cars and Trucks: Brake System Bleeding Tools - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Details here:
Hey guys, Is there any DIY on how to bleed the brake fluid? I also would like to use the Motive Bleeder, does anyone the size of the master cylinder? If we don't die from the COVID-19, I hope to hit the track in a month. The pads and fluid better be here
teslamotorsclub.com
HTH,
a
