Not sure about this, but I think it's energy per kilogram of battery. The new cells are bigger so there's less casing and more actual battery per kilogram.Even if the increase in range is 54% how can the energy content be five-fold?
That was a disappointment. I'd thought that when my M3 batteries died, I'd be able to replace them with the better battery, but it looks like they won't fit in my M3.
I will freely admit to not understanding the computation that shows such an increase in range (the stated increase ought to give a 300 mile range auto another 50 miles or so of range??). My intent is to order our MY in Oct (long story as to why then). I was hoping for a longer range vehicle then is now the case. Not sure that's going to happen.
Rich
From your computer to Elon's eyes, I hope.As long as your pack doesn't die within the next year then the truth is we don't know. The 2170 cells you have measure 21mm x 70mm, but the cells are contained in a module that is actually 90mm thick. Which then are contained in the pack's final form factor that's even thicker. The new unveiled 4680 cells are certainly a lot wider at 46mm but only marginally taller at 80mm. Leaving 10mm of clearance instead of the 20mm of your current modules. It's not identical, but it's by no means a challenge that can't be overcome and certainly not the first, second, or even third time that Tesla would have re-engineered a pack but kept the final form factor.
Maybe by 2030, when your battery is too degraded and needs replacement, they will have something even better.![]()
I think the main takeaway from the entire presentation is:
16% increase in range based on battery design alone (read: better cell geometry = more capacity). Also important is this is not vaporware... these are batteries being produced, right now, at a scalable prototype facility. A ~50% increase in power transfer rate due to tabbed design (i.e. improved thermal characteristics) (read: decrease in charging time) while not directly stated in the presentation the insane power output of an electric vehicle is merely a direct correlation of a battery's ability to discharge at the same (or greater) rate that it charges. As charging times decrease power output for a battery pack naturally increase.
- You can order your Plaid Model S now (<2 second 0-60) ...btw it's a family sedan.
- Tesla has secured its own lithium source... locally... in the U.S. to be used in it's own Gigafactory(TeraFactory?) using a new process that removes most of the current manufacturing steps. Said lithium source is enough to "electrify" the entire U.S. vehicle fleet should the entire reservoir be purchased and only in that one state. (there will be no lithium shortage.)
- new battery pack design will be structurally integrated into the car increasing overall car strength while decreasing overall gross vehicle weight. While not currently available for your new model Y, it was directly stated that this will be the way all their cars are built as new factories come online and/or it is feasible to retool.
- Plans for the TeraFactory... seriously they built a GigaFactory in 18 months. Only the ignorant are betting against this.
Any one of these talking points would have other vehicle manufactures throwing a media commercial parade... for Tesla just a Wednesday...
In the slides it literally says range increase of 54%. That definitely mean car range otherwise it doesn’t make sense.the 54% increase is per single cell.
as the new cells are much bigger, the volume is 5,5 times larger, here comes the higher capacity per single battery
I calculate that the 4680 battery has 4.8 times the volume of a 2170. Pretty close to their claim that the new cells will have 5x energy capacity.So higher C rate? What's the energy density improvement by volume and by weight?
The new cells are bigger. Imagine having a battery cell that has 5 times more volume, although this is smaller than that do to other improvements.Even if the increase in range is 54% how can the energy content be five-fold?
Sure about that?the range is increased by 54%... please change the headline!
Exactly. Their graphic showed the new cells having 6x power (presumably than 2170 cells), which equates to 16% more power/range.Sure about that?
I heard 16% from the dark-haired fella on the stage.
