What 2 parts? The arm with the break is in one piece. It's bent "in half" but still intact as an arm.
Maybe, or the top break is resting in the middle void/ lip.
So which is it? Is the only broken part the upper camber arm, or was the brake line broken, and two wheels bent as well?
Those must be some huge bots dots to bend wheels. (I have never seen those kind of dots bend a wheel before.)
Looks like the anti-roll bar link in the photo of the front suspension is slightly bent. (Buckled)
That would match well with a 5000lb car clotting the inside curb of a corner. I think this will be obvious if you ever post the photos of the wheels.
It would also be interesting to know the exact intersection where the sudden failure occurred. (Direction of travel, etc)
Learning all kinds of things about cars reading these threads and trying to understand about certain parts. One thing I read with regard to Control Arms is that if they are going bad there's a few things that can be noticed: loud banging or clunking sound when driving over bumps or turning the car, wheel assembly moves or shakes (noticable when jacked up), steering wheel feels loose, steering wheel or car vibrates when driving at anything over 30mph, tires have uneven wear (if PSI is at kept at correct level and tires are cupping or warping time to check the arms).
OP did you or your wife notice anything like this before this happened?
Oh sorry, just noticed your updated info post about a revision on ID'ing the part. Now need to learn about camber arms. I do know cambers are designed to keep your wheels/tires flat and vertically straight on the road. Are there "warning signs" for these if they are going to fail?
For anyone like me having trouble knowing what part we are talking about, I think Jeff Chan's site has 2 nice photos of the upper and lower cambers (photos 3 and 4): Comments on Tesla Model S public engineering presentation The photos are clickable for a larger image. So am I correct that the Air Suspension is attached to a part that's bolted to the upper camber arm? Can someone outline the sequence of events on how all these parts and damage would come into play. Assuming a broken camber would start it. Also thinking when the shop said OP's car hit something they were refering to something more like a pothole that would cause the wheel to jerk down quickly and stress the part?
Wait, I thought she ended up stopping on the dots... So, the vehicle has two bent wheels on opposite sides, and ends, of the vehicle and the thought is that this damage occurred by hitting some dots below 35 miles an hour after the part failure?
So Final finding is that 2 bent wheel, 1 Right Front and 1 Rear Left, 1 Broken Upper Camber Arm, 1 Brake line.
Just for your reference I attached one of the Dot I found on the scene Today. It is a Decent size DOTS
So you've got two bent wheels and a broken suspension component. Yep, that's clear evidence the car hit something, curb, pothole, chunk of concrete on the road.So Final finding is that 2 bent wheel, 1 Right Front and 1 Rear Left, 1 Broken Upper Camber Arm, 1 Brake line.
1 right front wheel and 1 left rear wheel were bent due to that she ran over them trying to stop, no other damage part reported beside the the brake line.
I had the same reaction. This is very puzzling. How can two wheels on opposite corners get "bent" at the "low speed" the OP describes due to a single fractured upper camber arm? I'm really trying to understand this scenario and it's not making sense to me. It takes a lot of force to bend a wheel.So, the vehicle has two bent wheels on opposite sides, and ends, of the vehicle and the thought is that this damage occurred by hitting some dots below 35 miles an hour after the part failure?
If the dots are large enough to bend the rim, then a car pulling onto the right shoulder could hit them with the right front and left rear, assuming the car ends up to the right of the dots. Or like @jaguar36 suggested, the bends were from a different event.
Heck, I've had to get the alloy rims on our mid sized SUV fixed 3 times, and those aren't even low profile.
If you hit the dots with the right front, and left rear, it would be unlikely that the vehicle would come to rest on the dots. You would think...unless someone turned back towards the road.
I would say that if the wheels were previously bent, especially the right front, that may have had an impact on the "failure" here. As an aside, would you not notice two previously bent wheels? I've never had a bent wheel.
are the p85+ control arms different? these are my upper control arms (that may get replaced)
https://1drv.ms/f/s!AihnWpuO55swh-Vh-w_bdIdjmP4MbA
that's interesting, because the ranger called it a control arm. learn something new everyday
thanks
thanks
you're right mongoHi,
The broken piece on the OP's car is the camber arm, your pics are a control arm (I think).
