Tesla Upper Control Arm CRACKED
I think your best bet is taking the repair bill to the city or university (or property owner of the road) and make a claim for reimbursement of damages caused by obstacles they chose to install on the roadway.
Are there any posted warning signs leading up to these bumps cautioning drivers their cars will receive severe damage if they don't stay in their lane? Collect more evidence.. You're on the right track collecting the broken bits of dots, etc.
I would totally be taking this to small claims court if they don't offer to pay the actual bill. But in court I'd raise the price to double for the inconvenience you've had to go through getting repairs ... rental car bill, if you have one, etc.
Make a case with the judge that you had a car malfunction and reason to pull over and did so and this is what happened. Find the article about driving on roadways and what you're supposed to do if your car has a breakdown ... does it say something like "if you can, pull over safely to the side (which side - nearest or right side) of road?"
Could you safely do that here? Turns out "no". This is road safety issue.
They may be ordered to remove all the dots - save all our cars please.
Thanks so much for your input
Yes This really got me thinking that I might have to taken this up further to the city or the college to have them look into those Hazardous Dots.
My insurance has decided to cover all the repair as well and replacing all the damage wheel. Anyone in the SoCal Area Please do no go to Buena Park TESLA
The service Adviser Vince is not only conceited and were completely not courteous at all. I am not sure how Tesla's Hiring process work but this adviser need to be gone. Their service adviser is by far the worst i have ever encounter. I been with MERCEDES for over a 15 Years I have not even once encounter any service adviser that were this bad. NO PHONE CALL EVER RETURNED, NO KNOWLEDGE OF THE CAR, Simply the Worst.
My Only Regret was bring the car to the closest tesla service center. May be that is the reason why they have a 3 star rating on Yelp
Obviously they will get another 1 star from ME
Also not sure if TESLA really care about customer service as i have made several request for the Regional service manager as well as the branch manager. NO RESPONSE from both.
Now that your insurance has covered it, you can breathe a sign of relief. However, insurance payments are on the backs of everyone who buys insurance as rates go up. Since the insurance paid for the damage they would have to be going to court / approaching the city or college for reimbursement. Which I bet, they won't. It's not your issue anymore it theirs.
Easy to push the issue with insurance so you don't get hit with it. The subrogation can be requested.
Reactions: neroden
This is an Update on the control arm cracked issue
I finally were able to get the vehicle back about week and a half ago but never had a chance to get a chance to sit down to examine the switch out part
here are some pictures of the 2 upper control arm
Not sure how this would justify but with such a crack on the control arm I think the car would sustain tremendous damage
but no body work require to fix the issue only the suspension part replaced, also 2 damage wheels
I still believe that it is a part integraty issue. Although the part of the wheel were bend the wheel itself still hold up air and cause no vibration when driving. I have not driven the car at a high speed yet. I am waiting for my replacement
wheel to arrive before we will take the car on the road again.
Reactions: cwerdna and Az_Rael
Personally, I'd have used an I-beam forging instead of a cutout billet. It would have been stronger at the same weight. But that is not defect, just a less than optimum decision.
The fracture shape is interesting. If I were going to do fault analysis, I'd look at grain direction. The grain should have been horizontal. The fracture looks suspiciously like a "with the grain" crack, ie - grain direction is 90° out of phase. This occurs when companies use part clustering CNC software to maximumize the number of components that can be made from a single sheet of stock, if you forget about grain direction, some will have the wrong direction.
Aluminum is like wood. It has a grain direction. Single sharp cracks with no deformation from bending is normally how 'with the grain' failures look. Against the grain usually shows significant bending before the crack becomes visible to the naked eye.
This is supercritical on flight hardware.
Which way are you suspecting grain might run on this part, and which way are you suggesting the grain should run?
Refer to diagram below, and the blue and green lines as being "with the grain" in the direction shown, per line.
Which is which?
p.s. if a machinist were to make aftermarket forged I-beam arms... I'd consider buying a set and proactively replacing them.. if the price was right.
p.p.s I've seen a sticker on my rear suspension arms that they were made in Canada. And I've seen made in Canada on the front upper A-arms that I just bought because their ball joints are worn. The front upper arms are stamped steel parts, whereas these rear arms are aluminum.. wondering if the same shop in Canada makes all the arms for Tesla?
A friend had a S and bent the exact same part after hitting a deep pothole at speed. It was still drivable. If the friend continued to drive it it might have eventually cracked.
It was replaced pretty easily. not a big deal.
Very likely some pothole type hit occurred at some point, stressing the metal, and then it eventually failed.
There is another thread on this.
(yawn)
I still believe that it is a part integraty issue. Although the part of the wheel were bend the wheel itself still hold up air and cause no vibration when driving. I have not driven the car at a high speed yet. I am waiting for my replacementView attachment 249199 View attachment 249200 View attachment 249201 wheel to arrive before we will take the car on the road again.
Reactions: brkaus and cwerdna
Aluminum actually has 3 grain directions. Long Transverse, Short Transverse, and Longitudinal. Depending on the alloy they are using, the properties for each of those grain directions are different.
We once had a problem with a new aluminum alloy we were using at my work. It turned out to be brittle in the ST direction. So even though our grain direction was correct for our load paths, we ended up having cracks when we started using thicker billets that had more of the ST direction involved.
Which is which?View attachment 249203
Longitudinally is how the grain should have went on a billet for maximum strength and fracture resistance.
The blue line is not the optimum direction. The green line would have been superior but not optimal.
But lacking a beam structure is a more important problem.
There may be other factors at play here for the design. There could have been some mandate for that part to become a sacrificial part to protect other much more difficult to replace parts in the even of a minor impact. It could also have been designed that way for proper crash worthiness aspects.
What was his offense? That he pointed out, what was almost certainly true, and supported by evidence and reason and experience, that the failure was caused by a pothole or other obstacle type hit? Which, by the way, would have to be the case for your insurance to cover it -- your own auto ins doesn't cover mfr defects.
Reactions: JohnSnowNW
Everything you have stated here is correct. However, over at the MB dealer, they are smart enough to cover all of this in the interest of future sales. That is an attitude that their customers pay a premium to enjoy. If Tesla wants the service network to treat customers like they are at the Honda dealer, many customers will go elsewhere as soon as there are premium EV options...and that day is fast approaching.
I think the part did very well. It held together even though it was deformed. The fracture mode looks like textbook tensile overload with failure on a shear plane.
And I’m not willing to guess anything about grain direction or grain structure without looking at it with a microscope.
From this distance, it looks like it had a heck of a whallop, it did its job, and give its life trying :(
This part is probably not made from billet because the slot that cracked has too small of an internal radius for efficient machining.
It is quite likely die-cast, as that should be by far the cheapest and fastest way to produce the part in larger numbers.Most of the other suspension parts are die-cast as well.
Castings in general will have some issues with porosity and are typically far less ductile compared to rolled or forged material.
Reactions: GSP and Jeff Hudson
grain goes in the wrong direction and that it's weaker than a forging.
I agree with this, with the caveat that it is not evidence of a defect.
It could certainly be accounted for in the design. We have no way of knowing what materials properties and max loads were used in the design process.
And, we don’t know if this part was designed to fail first as an energy absorbing mechanism.
Reactions: GoTslaGo
