Hello,
I've had sterling service for about 15 months from my HPWC, but in the last couple of weeks I've had a number of occasions where it's not starting to charge when plugged in. Symptom is light-blue light on the car, insert connector all the way, delay, light goes out and lock but nothing - single static green light on the HPWC and "Ready to Charge" on the car's screen. If we then re-arrange the cable (it's the 7.5M one so there's quite a bit of slack), most of the time charging will start. This was the clue that made me think cable not car or charger itself (the car's fine on SuperChargers or the Mobile Connector so we've ruled that out). Have checked car and connector's ports for any debris etc, nothing. And I had the cover off the wall charger (isolated at source) and tested continuity - no problem with Earth, and the AC pins, but one of the two signal pins proved very hard to get continuity on.
All of the above is basically to highlight that I'm pretty sure there's a continuity problem with one of the signalling wires at some point in the cable (although I should stress there's no obvious external signs of any trouble, no nicks in the insulation or anything). I've put in a service request to Tesla as it's within warranty but haven't heard back yet. I can't find anyone else anywhere online with this specific fault (plenty of problems with the HPWC itself, I'll note, and plenty with the car's connector port, but none specific to the cable). So as a hail-mary: Anyone else had this and if so what did you do about it?
