serendipitous
I had no problems for a few weeks (mine replaced an overheating Gen2-with-14-50 plug). But last week after coming back from a long trip and charging in a hot garage for a long time, mine gave the three red lights and stopped charging. I didn't check firmware at the time, but I do have 0.8.58 now and haven't had the issue after that one time. It was the hottest day of the year so far (~105 degrees), with a heat-soaked car in a hot garage, so not sure if the connector is just riding at its thermal limit, or if it maybe was addressed by new firmware.
I had this also and figured it out. If you have it on a 60A circuit (48A charging), then you need to re-do the commissioning process (power down, power on, connect to its WiFi network, and go through commissioning), and select a different amperage checkbox and then back to 60A, then complete the installation. If you just leave it defaulted at 60A on that screen it doesn't register that you've consciously configured it I guess and says Partial even though it's all set. You can only change the amperage by going through the commissioning process - not after it's settled on your home WiFi, even though the wizard implies that you can change it later. Doesn't seem to impact anything other than that "Partially Configured" display item.
I also noticed that my charger shows "partially configured" when I connect to it. No idea if this is related to the red light problem.
