I read several threads where people were asking about connecting their Tesla Wall Chargers onto an existing 50 amp circuits in their electrical panel. I believe most of these were talking about utilizing existing 14-50 electrical dryer circuits for their Wall Chargers installs.
I was watching a recent Sandy Munro video where he was talking about (warning about) people who connect using the wiring and breaker to this circuit (48 amps wall charger) Warning that these residential circuits are not meant for a continuous 50 amp load and are intended for partial duty loads as you would see with an electric dryer, which is not going to run continually at full load for hours and hours on end perhaps every single day. He showed samples of melted connectors, torched wiring from people who had installed their wall chargers this way and were charging every day etc... He talked about how you need to have 60amp circuit for a Wall Charger and use good components meant for continuous duty.
I just had a dedicated circuit installed for my Model 3 Performance by an electrician (before I saw the Munro video), and I remember the installer saying that the 50 amp circuit they were installing was more than fine for my charger. Especially since he used a double 50amp breaker that I supplied that he said worked fine in my Eaton electrical panel. He actually said it was overkill. It is a Siemens unit and cost me over $100 (I just asked the guy at the counter (what's the best one you have?)
But I was worried because Mr Munro said the circuit is supposed to be designed for a certain percentage in AMPS above what you're sending thru it. I can't remember what that percentage was.
Worried, I looked at my invoice for the work that was done, and the wiring length is 23' of "#6 THWN-2 in flex metal conduit" and with my 50amp Siemens breaker and Tesla Wall Charger listed as customer provided.
My understanding is that the Wall Charger pulls 48amps max. Is the fact I have a "only" 50 amp breaker installed bad? Doesn't that mean that it will trip at 50+ rather than 60+ if I had that sized breaker installed? I looked up THWN-2 #6 wire and it said it is rated for 190 C and 75amps so am I good to go the way I have it set up? Or is there something I'm not considering (not an electrician here)
Thanks in Advance!
Thanks in Advance!
