Which means you have a Gen 1 UMC, so it’s irrelevant to the current discusssion. The UMC being provided now, the Gen 2 UMC, draws a max of 32A from a 14-50 outlet.Mine maxes out at 40A.
How about both! I have added a 14-50 to my Tesla Wall Charger and it works flawlessly. Now I have a Tesla charger I can move from place to place (I rent a townhouse and didn't want it installed "hard wire" but the landlord let me add a 14-50 socket to the garage)
Check it out....
Tesla Wall Connector Installation
Tesla also sells a 14-50 only connector - which will charge at up to 40A from a 14-50 outlet - which is what we are currently using for our X 100D.
We have our referral HPWC in a box - and are considering installing to where we have the 14-50 outlet. Would prefer to add a 14-50 plug onto the HPWC, to simplify installation/de-installation.
Though since the only advantage of an HPWC vs. a 14-50 connector is that the HPWC looks cooler, not sure we'll want to spend any $$$ to get it connected to the available 50A power on that side of the garage...
Installed a juicebox Pro40 to charge our i3. Works great for the Tesla. You can order it with the 14-50 connector or as hard wired. Can be installed outside.
Can you give more info on your potential setup? Is the potential charging spot in a completely exposed and publically accessible place, more private? Wall connector seem to make sense more for outdoors setup, but there are options for securing your UMC on the exterior as well.Hi guys,
I just purchased my Model S and I was wondering whether I should get the Nema 14-50 or the Tesla Wall Charger installed in my house, fyi, I'm parking my car outside by my garage.
Thanks
You do not help battery longevity by reducing the charge to 12A. You do waste a lot of electricity that way, though, and run the charging cuircut in the car much longer than you would if you charged the way the car was designed.I installed a NEMA 14-50 with 50A breaker, just use the charger that comes with it for my daily 60 mile commute, and ramp it down if 12A to help battery longevity. Charges me to 80% overnight easily (as I limit it to). Honestly don’t see the need to charge at 50A+, 32 is quick enough
Seems like a lot of people are concerned with how long it might take to charge the car.
At night, I'm asleep. I don't care. The car is always full every morning, and I use the 14-50 that came with the car. Why buy anything else? Waste of money.
The basis of this is that you're talking about the difference between 7kW and 3kW of power levels. The car routinely takes 115kW at a Supercharger, more than 16X more powerful than that. All of these home charging rates are so agonizingly slow that it's meaningless to the battery longevity.What is your basis for this?
