There is no reason why you cant just put the plug on the wall charger.
Well, except for it no longer meeting its UL certification. That may or may not matter to you or your insurance company if things go wrong.
It’s because UL states that in order for their marking to be valid, the product must be installed in accordance with its instructions. Nothing to do with the qualifications of the installer.That doesn't make sense. If you must, have an electrician do it but these aren't hard to wire up.
I've watched the videos on YouTube. It's not easy if your not a electrician. And I don't want to hire a electrician. Again I have the Nema 240v socket. Just looking for the Tesla wall module that plugs into the socket.That doesn't make sense. If you must, have an electrician do it but these aren't hard to wire up.
They never ended up selling it in any sort of quantity before discontinuing it. It’s unlikely that you’ll find one. You can have a wall connector installed in place of the NEMA 14-50 receptacle or you can use the mobile charge cord.
If your 14-50 outlet is a Leviton brand, I recommend replacing it anyway, as their poor construction is a fire risk.
This one?
Corded Mobile Connector
It's out of stock. Click the "email me when this item is restocked" button.
Why do people keep saying it has disappeared?This one?
If it was “discontinued”, why does it say “out of stock” and an “email me when the item is restocked” link?
You linked to the page for the Gen1 Mobile Connector, but this thread is explicitly about the Wall Connector with a NEMA 14-50 plug rather than a "pigtail" for hard-wiring. Although the two devices are functionally very similar, they aren't identical, and some people want a Wall Connector with a plug. Without further information, we can't be sure if a Gen1 Mobile Connector would suit @CJtes's needs. I just checked, and I couldn't find any sign of information on a plug-equipped Wall Connector on Tesla's site right now, but I have seen mention of such a device being sold from time to time, including just a few weeks ago, IIRC.
corded mobile connector is out of stock, corded wall charger is "missing"
Does the Wall charger with the Tesla 14-50P connector and factory cable have the temperature sensor built into the plug? If not, what is the advantage of not having an electrician wire up the model designed for direct connection? Seems to me it would be no less safe. Do any of the other chargers made by other manufactures have temp sensors built into the plug for safety?
The main reason people want these is because they already have a NEMA 14-50 in their garage and this would be a self install rather then having to pay an electrician $$$ to hardwire it. A few other reasons come to mind to as well...
It's easier to remove if you decide to move
If the wall connector fails you'll still have the NEMA outlet to fall back on
Having the option to use the NEMA outlet for other types of EVs, RVs, rented tools, etc...
The NEMA outlet is much more flexible then a single purpose hardwired Tesla only box.
