Right now I am planning on installing a 14-50 plug that will have to run around 50 feet total (box to outlet) through my attic. i already have one referral though and assume I could get another sometime which would get me a wall charger. Would a 100 amp box be able to support a wall charger? or is it certain I would need to upgrade my box? Right now my max 15 minute meter draw is 1.62 kwh or roughly 6.5 kw in an hour with my dryer taking up 1/2 of that.
My main question was mainly going to be what wire I could use to do a 14-50 amp now and just upgrade to the wall charger later without redoing everything. I assume use 50 amp breaker for 14-50 and 60 amp breaker for wall charger om my RWD Model 3.
That's if it doesn't cost to much to redo my breaker box if needed. I should be able to add the 14-50 with no major upgrades. My first quote was $845, but seeing if I can get a friend to help on installing that and have his electrician dad confirm its good to go.
