I have my wall charger hooked up to a 50 amp circuit but the car is charging at 32 amp/7kW when I was expecting it it charge at 20 amp/11.4kW. can it be set to charge faster?
It's not about age. Only LR and Performance versions of the M3/MY can charge at up to 48 Amps when connected to a wall connector.
On a 50 Amp circuit you would be limited to 40 Amps (9.6 kW) if your car was a LR or P. You'd need a 60 Amp breaker to be able to charge at 48 Amps/11.5 kW.
Wall Connector is the most convenient charging solution for homes, hospitality properties and workplaces. View the charging speed based on your model and find out how to install a Wall Connector.
www.tesla.com
50 amp breaker: 40 amp / 9.6 kW
> Maximum charge rate for Model 3 Rear-Wheel Drive is 32A (7.7kW)
